Ultimately it's Kent's call, to further the issue, it appears that some Leaf's charge on the CS 100's, some don't. the 2012 and 2013 do not work on my unit here at the house, it's being swapped out for a 70A unit. the simplest thing at this point will be to go with the 70A for phase 1 in WA state, which is the core of the Sun Country Highway in Canada, they have a proven track record of working with everything. 100's will be added as well.
No, it doesn't. It's a bone simple modification. Switch, placard for switch, wires to circuit board to adjust 1kHz pilot signal pulse wave modulation... see, simple!
- - - Updated - - -
Except you don't have any control over if/when will "fix" a car that they don't even build any more, and that doesn't really need fixing (there certainly is no guarantee when the car was sold that it would work above 70 amps).
Hence, the switch on the CS-100.
