Yea was trying to avoid driving around pointlessly. Was thinking maybe if i can set the supercharger as destination from the app and maybe wake the car? IdkDrive around for 20 minutes with the Supercharger as destination in the Navigation system.
Just setting the destination as the Supercharger won't initiate fully warming the battery. There are several temperature thresholds while preconditioning the Tesla Model Y. For Level 1/2 charging the battery pack must warmed to at least 10C (50F), preconditioning will raise the temperature of the battery pack to 20C (68F); Preconditioning on route to a Supercharger will further warm the battery. I believe the optimum and peak temperature of the battery pack for fastest Supercharging is 44C (112F).Yea was trying to avoid driving around pointlessly. Was thinking maybe if i can set the supercharger as destination from the app and maybe wake the car? Idk
Would you have to sit in the vehicle in Drive with the brake Hold set, is that safe? As soon as you unbuckle the seat belt and open the driver's door the Tesla vehicle will shift into Park.As long as the car is in Drive with the supercharger set as the destination, it should precondition the battery, even when stationary.
You should buckle the seat belt, before seating inside the car, and then press on the break pedal while putting the car to N (neutral).Would you have to sit in the vehicle in Drive with the brake Hold set, is that safe? As soon as you unbuckle the seat belt and open the driver's door the Tesla vehicle will shift into Park.
I've never observed preconditioning my Model Y using more than 2% to 4% of the battery SOC even after 45 minutes.There are some stats that show pre-conditioning uses quite of bit of energy. Sure, you can charge faster, but if you are low on charge, maybe re-think pre-conditioning?
yes it is. So how would I precondition from home without having to go the car?Is the nearby Supercharger an Urban Supercharger? Urban Superchargers are limited to 72kW charging rate. You might be ok with just preconditioning for 20 to 30 minutes while parked at home before driving the short distance to the Urban Supercharger.
Your Tesla vehicle has to be parked where it can receive a 4G LTE phone signal or WiFi signal. Then use the Tesla app on your phone to turn on the climate control. Depending on the season and the outside air temperature you should plan on preconditioning for 10 to 20 minutes. In very cold weather you may have to precondition for more than 30 minutes. If the battery pack is cold enough the Tesla app will display a red battery indicator showing that the battery is being warmed during the preconditioning period. The Tesla vehicle does not have to be plugged in to use the preconditioning feature via the Tesla app. Leave the climate control settings as you normally like them set, including the seat heater and steering wheel heater, before exiting the vehicle. You can adjust the cabin temperature setting and the seat heater(s) from the Tesla app.yes it is. So how would I precondition from home without having to go the car?
In winter not the warmest setting, just set the temperature to your usual cabin temperature, i.e. 70F to 75F. I prefer to leave the climate control set to Auto (this is set in the vehicle climate control settings, not the Tesla app.) The only time you would need or want to use the maximum heating is when defrosting the windshield and windows. The windshield defroster icon has two settings. Blue for defogging the windshield and Red for maximum defrosting of ice and snow from the windshield. I believe the the rear window defroster grid will turn on if you select the windshield defogging or defrosting function (for ~10 minutes) Leave cabin air recirculate off to avoid fogging the windows in winter. (Other than turning on the climate control via the Tesla app I sometimes raise or lower the cabin temperature setting by a few degrees up or down and adjust the driver's seat heater setting to Low/Medium/High/Off. You can turn the climate control On and Off from the main screen of the Tesla app simply by tapping the fan icon (the left most screen button. Note that you only need to access the climate control settings screen from the Tesla app if you want to adjust specific climate control options or adjust the cabin temperature setting or the seat heaters. Otherwise a simple tap of the fan icon will turn the climate control system On or Off.ok this helps. So when I turn the climate on what should it be set to? In the winter I'm assuming make it the hottest? But in the summer?
FYI it's 116F when the Stator motors shutoff during L3 charging.Just setting the destination as the Supercharger won't initiate fully warming the battery. There are several temperature thresholds while preconditioning the Tesla Model Y. For Level 1/2 charging the battery pack must warmed to at least 10C (50F), preconditioning will raise the temperature of the battery pack to 20C (68F); Preconditioning on route to a Supercharger will further warm the battery. I believe the optimum and peak temperature of the battery pack for fastest Supercharging is 44C (112F).
