I'm a bit confused on some PW code issues. I recall seeing on a thread here recently that PW2s now should be installed 3 ft apart. I currently have 1 PW installed in a utility closet in the basement. I plan to add 2 more shortly.
The following is from the NFPA 855, Standard for the Installation of Stationary Energy Storage Systems
Installation of Stationary ESS page 855-18
9.4.2 Size & Separation
9.4.2.1 ESS shall be comprised of groups with a maximum stored energy of 50 kWh each.
9.4.2.2 Each group shall be spaced a minimum of 3 ft (0.9m) from other groups and from walls in the storage room or area.
In a 2-yr old NFPA blog, is states max 40 kWh in a storage space
Residential Energy Storage System Regulations | NFPA | NFPA
I'm planning on adding 2 more PW. I believe that totals 40.5 kWh storage space.
My question is: In a basement storage area, do 3 PW meet the new standards and can they be grouped together or does each PW have to be 3 ft apart? Even if allowable, is having three together a concern? Thanks.
