Gonna sleep on this for a while.
I have no idea what that means or what to do with it.Heavy cables are where residential 3 phase power rules. To distribute 22kW you need 5 wires capable of 32A, that's 6mm² or AWG ~9.
Now there's an idea! The HPC is cheaper than the UMC anyway and would look nicer and do the same job. now I have MORE ideas to sleep on!!you would rather use the better looking HPC in your garage, then just wire it to your 14-50 outlet and program it for 40A.
GSP
On Roadster roadtrips, I've used my UMC heavily. There's always an RV park around with 40amp service. (Plus I carry my J1772 adapter.) I'd get the UMC.
I'll get one UMC either way...is there a good reason to use a $1500 UMC semi-permanantly installed in the garage instead of the $1200 HPC? (assuming the prices are consistant with Roadster prices in the shop right now).
I use one UMC between the need to charge at home and on roadtrips. I just unplug it and put it in the car when I'm going to be out in the wild. I don't bother when I'm going to destinations with known charging infrastructure, so it's probably only a couple of times a year that I unplug it and throw it in the car. So if I were you, I'd get just the UMC, install a NEMA 14-50 plug at home, and make it do double-duty.
I do like Bonnie does: I have the UMC (240 v 40 a) and it lives in the garage. If I ever decide to do a road trip, I can take it along. At first I kept the 120 v EVSE in the car, the one that comes free with the Roadster, for emergencies. But I soon realized that was silly, and it takes up too much space in the tiny trunk. If I ever miscalculate I can call for a tow. That would be extremely expensive, but even more unlikely, as I'm careful.I'll get one UMC either way...is there a good reason to use a $1500 UMC semi-permanantly installed in the garage instead of the $1200 HPC? (assuming the prices are consistant with Roadster prices in the shop right now).
Note that two cars can be charged from one outlet if you have the flexibility to switch them around. If I ever get the electric Porsche back, it will charge from the same NEMA 14-50 as the Roadster. It will be a minor nuisance, but less so than having another 50-amp service installed.
I installed my 14-50 plug in the center of the garage - on top of the "ties" at both of my garages. This allows me to easily charge the car no matter which side of the garage I park or if I pull-in or back-in.
I understand what you're saying, but I'm just not going to risk forgetting to put it in the car if I take off on a longer trip, or unexpectedly find myself taking a longer trip and wanting or needing to charge. Call me a Boy Scout if you will, but I want one that stays in the car 24/7. I expect to do enough longer trips and know how often I've forgotten things as important as underwhere and wallet that I'm not gonna risk being 160 miles from home with 50 miles of range and no UMC to remedy the situation
Evan,
with the J-1772 adapter that's going to come wth every Model S, you would never really be stranded, you could probably find a "ChargePoint" J-1772 EVSE in most major cities you road trip to, would be my guess. With that small adapter cable, you have access to lots of public J-1772 EVSEs (most are 30A capable, only 10A less than the UMC w/the 14-50, so just %25 slower overall). You can leave the 50A portble EVSE at home, and still be not worry too much about being stranded. Just a thought. Checkout the areas you travel to, see if there are any public J-1772 EVSEs.
Find Stations - ChargePoint Network
You're right that there are now J1772 chargers in many cities but usually none between big cities.
Good point. I guess I should say for Texas at least, there isn't a single J1772 charger in the 200 mile stretch from Houston to San Antonio and Austin to Dallas. I guess it's important to look ahead and plan your trip to see what chargers are available. I'd still bring the UMC with me on longer trips since that opens up almost all the RV parks with faster 40A charging.A lot depends on where you are. In CA, J1772s are all over the place, including in small towns such as Castroville (pop 3100).
