Just a note: There won't be a direct SOC-to-voltage translation. SOC will be calculated from an energy balance equation, measuring total pack energy output, and decreasing a counter as the pack energy is decreased. Possibly the below zero mile shut down will occur at a specific cell voltage, but this will not be used to determine capacity.
Ah, good points. I'd also assume that local variables such as temperature might be included.
Nonetheless, I'd expect that some things, such as a full 10% difference in reported charge from 90 to 100% correlating to only a 50mV voltage differential might set off some alarms as being unlikely.
Nonetheless, it would be interesting to see if we can at least document the extents as within the car's normal operational envelope.
- - - Updated - - -
Good summary.
Back in the Roadster days, Tesla wrote a technical blog that covered behind-the-scenes details on the car's design and operation (I miss those!). The Roadster also dumps a set of log files every time a properly formatted USB stick is inserted in the port, which members on this forum have reverse engineered. Parsers and graphing tools are available on several threads. A few members also have access to the service screens, which have real-time brick voltages and SOCs.
Model S is a lot more locked down by comparison, but it's just a matter of time before the collective intelligence of this forum figures it out.
I should have said: "How did
YOU Roadster guys get this data!"
Seriously, a lot of trailblazing was done there, and even if not all the specs area directly transferable, a number of the principles and methods no doubt are.
I agree that it's threads like this one that will help document what the S and it's pack does. My post was not intended to throw any cold water on this effort, quite the contrary: I applaud this thread and the work wk057 is doing.
What I'm really hoping for is clarification from folks so we can determine what is known as fact, either via direct observation/measurement, or from some authoritative source (manual, part # spec, etc..). For the rest of the input, I think it would be helpful to qualify it as a informed speculation (and upon which basis), and/or extrapolation from elsewhere (Roadster data, similar cell specs, etc...)
Cool stuff...
