Does anyone have experience in ensuring things are optimized for maximum monetary offset? I’m PGE & EV2A rate.
My understanding is that PGE has a cap to how much excess generation you can send to the grid each month, based more or less on the PVWatts calculations once all your system parameters are passed in.
Is this the the theoretical maximum in a “net” (usage - generation) calculation? Meaning you could almost never hit this threshold assuming you live in the house and consume electricity? Or is this a generation only limit?
I thought I remember seeing somewhere that you need to be careful about not generating off-peak onto grid, because PGE would count those kWh’s first, and then prevent you from getting high $ credit for peak generation kWh’s.
Also, I plan to use 4x powerwalls to TOU shift my generation. On most days (in the summer at least) I should be able to fully charge the powerwalls during the day as well as manage small home loads. Is Time Based Control smart enough to wait through the shoulder period and not generate to grid until it’s actual peak (not partial peak) to fully maximize cost benefits? Or do i need to manually adjust the rate plan amounts to force it into more ideal behavior?
