After 40 miles of electric-only running, the engine fires up to generate the electrical current required to propel the car and maintain the battery charge.
The 30-litre fuel tank gives 311 more miles of range. Economy is calculated at an incredible 175mpg.
Running on gas, I calculate 10,4 MPG. Still incredible, but....
Ampera / Volt to become a parallel hybrid...
I got this back from them, via Facebook:
Hi David, Vauxhall would like to state that there are no plans to make any mechanical or control changes to the Ampera before its launch in early 2012, and that the vehicle cannot be driven without electricity.
English somehow came to believe that General Motors was working on an update for the launch of the Volt that would see the installation of a mechanical drive between the engine and wheels to bypass the mechanical-electrical energy conversion inefficiencies. While GM's two-mode hybrid system does exactly this with a pair of clutches, there are no plans to do this for the Volt. GM spokesman Rob Peterson told GM-Volt.com that the Volt's drive architecture remains the same as always with the engine only driving a generator.
So calm as you like, you just floor the throttle. Now it's got your attention though, because off the line the Ampera has a surprising turn of speed.
At the top I’m impressed by the Ampera. To drive it’s close enough to a regular car not to put anyone off, it’s plenty quick enough up to 60mph and it disguises its weight well.
I’m genuinely looking forward to the next generation of EVs, because I believe the experience you get with instant torque really does offer something for enthusiasts to enjoy.
And if by using EVs for shorter, more routine journeys, it means we can continue to enjoy the spectacle of the internal combustion engine simply for the hell of it, then all the better.
- The UK price should hopefully be £30k before rebates.
