supratachophobia
I suspect Robert actually meant a 10-50 and got confused. A 14-50 provides 40 amp max of charging and a 10-50 could provide the same. So I can see how someone could mean a 10-50, but mix up and say 10-40 since 40 amp would be all they get from it.
For Tesla applications, a 10-50 and a 14-50 are basically the same as neither actually makes use of a neutral. So an adapter from 14-50 -> 10-50 wired up like a 14-30 -> 10-30 would be fine. That said, we all would recommend Robert provide more information or have a more "failsafe" setup installed to avoid confusion long-term.
Thanks, you explained what I meant. And if you did it that way with an adapter between a 14-50 and a 10-50, you wouldn't have to manually remember to dial down the amps.
