PatrickCH4313
You' are right, but you still have to provide payment information (credit card info!) at the end of the registration, even for the free trial !
It appears that 10 was sufficiently buggy they needed to immediately release a new version of it. That screams it's a critical bug(s) fix.don't pee in your pants with excitement. It is really about the same as 32.10 with tweaks and rolling out to different models at present.
Bonnie Norman, I don't know if she's on here appears to have skipped 10 on her S or X. Sounds like 11 is pretty buggy so I am guessing they fixed the most egregious of the bug(s) in 10. I do should, when doing Auto Steer that there is a blue lane and a gray lane. Problem is, they converge and diverge whereas a double yellow is a fixed gap.Yeah, when it first started it looks like S/X specific now it’s an update for all. Both my X and 3 got it yesterday; the 3 a few hours after the X, and after it already had 10. X never had 10.
sorry but no that is not the reason .11 followed .10. It might seem that way, but isn't.Bonnie Norman, I don't know if she's on here appears to have skipped 10 on her S or X. Sounds like 11 is pretty buggy so I am guessing they fixed the most egregious of the bug(s) in 10. I do should, when doing Auto Steer that there is a blue lane and a gray lane. Problem is, they converge and diverge whereas a double yellow is a fixed gap.
Really? Enlighten us. It has zero to do with model. It came directly on the heels of 10. There are still reported bugs in 11 so, yes, it stands to reason there was something in 10 that was deemed a critical to fix. I am not betting my first born on this but, given it's what I did for a living, it stands to reason ... short of an official explanation.sorry but no that is not the reason .11 followed .10. It might seem that way, but isn't.
I haven't taken the car out since 11 was installed. I just checked and I have wifi full bars and signed into NetFlix. I'd be tempted to say try rebooting your car but I always hated that as the recourse for a DOA Windows system. Reboot never fixes anything. It may circumvent a problem but it doesn't fix the problem. It's a subtle but important distinction.I have 11 installed on my May 2018 Model X and it has now lost the ability to connect to wifi. It can't connect to any wifi, mine or others, secured or open, and it's the MX not the networks as any other device I have tested with has no issues when connecting to the various wifi access points I have attempted to use with the MX. First time I have had this issue, the MX has its own access point in the garage that it's been connected to for 18months without any prior issues.
Is anyone else experiencing wifi connectivity issues post v10 software?
How? I also got MCU1/AP2.5 (11/2017) Model X and it does not have netflix. My Model 3 has it.
I tried once and this is where it started for me, too. I used go to target once before I used come to me, but I'm not sure that was necessary. After doing that, when I tried to set a target again, I subsequently noticed that if I hit the target button on the top right corner of the app a second time, it removed the target and then the button changed to come to me. I suspect hitting this button would work initially, too.I have a Sept 2018 X75. V10 came down last night, but I don't have a 'come to me' button, only the 'go to target' one. Does anyone else have this issue and is there a fix?
Got a new update this am. 2019. 32.11.1
I ended up doing that as well, an inexpensive repeater that only the car connects to. The firewall (fire door and likely protected wall between garage and house sufficiently dampened the signal from any interior access points. The inexpensive repeater allows for a full bars signal at the car, which Tesla told me it really needed to work. Since I installed that back last Nov I have no trouble with OTA updates. I thought your post reflected new behavior since V10.I did the two-thumb salute several times and I got the same result
I checked out some old wifi issue threads and found a suggestion of installing a cheapo access point for Tesla only connectivity with the shortest path (e.g. router only) to the internet. A network engineer discovered that there is a latency challenge with DNS resolution and then Tesla core-site access. The wifi connect sequence only succeeds when you get a response from Tesla core-site within a short window of time.
I connected an old Linksys access point direct into my router and set it next to the MX and it worked (the linksys AP is 10 feet closer than the main access point that now fails). When I get some spare time, I’ll fire up Wire Shark to see what’s really going on and maybe that will help me get back to my regular wifi solution.
If the reason it’s now working is a latency issue, then Tesla needs to open a larger wait time to allow wifi connectivity to work. The difference between working and not-working can only be a matter of milliseconds (~20ms I would guess)
BTW: Last night (2Oct) I got a second update to the origin v10 upgrade (now 11.1) and the problem is still there
