Why don't you actually look things up? These are the inverter part numbers (top one is LR and also shared with M3P). Roughly half the price of the MSLR / M3P rear drive unit
1120980 is the rear drive unit. It's cheap because it's shared with the model 3 / model Y which is produced in literally an order of magnitude greater volume. Front drive unit on the MSLR is *not* the same as the rear drive unit. Different gear ratio, different packaging. Power output is the same, but as it is a different part with a much lower production volume, it's going to be more expensive.
The drive unit assembly does include the inverter. The "MOSFET" reference is because there is a model 3 part ("970" motor) that used an IGBT based inverter, though I don't think that's made anymore (nor is that particular inverter available separately as far as I can tell)
