Somehow I managed to crack part of one of the plastic power window switch buttons in my Model 3. I must have Hulk fingers.
When I first noticed something was wrong, I was trying to raise the front-passenger window via the switch in the driver's door when I realized (A) it wasn't working, and (B) the button felt loose. At this point, it could still lower the window, but not raise it.
When I got home, I pulled out the plastic switch button out to investigate what was happening (it came out pretty easily), and found that some small bits of plastic appeared to have cracked off. (In the photos below, I've circled the areas where it looks like material cracked off. I'm pretty sure the two protruding bits on either side are supposed to be mirror images of each other.) And it appears that these bits that cracked off are what interfaces with the switch mechanism itself.
So I guess I'll be scheduling an appointment to get this fixed. Hopefully they'll be able to replace only the broken button and not the whole (probably expensive) switch assembly. But I'm not feeling terribly optimistic.
Anyway... since I couldn't find any reports online of this happening to anyone else, I figured I'd share in case anyone else runs into this same issue in the future. I'll post updates if/when it gets fixed.
