lolachampcar, the request information... presented as a picture essay :smile:Could you do me a favor and extract a bit of info while you're shooting pics of that suspension. Specifically, I'd like the unloaded and normal loaded length of the spring (I know, you can not get the free length without taking things apart), the wire diameter (and let me know if it changes) and the coil diameters tied to the number of coils with each diameter.
I must say - I very much enjoy reading your posts, especially with all the great suspension pics!With removeable perches, it may be possible to replace the existing perch with one set to the desired ride height or with an adjustable one. I think it is time to disassemble my wife's car which means giving up mine for a while
I think the reason you are not seeing any attachement points for the lower spring perches is because Tesla is using the exact same twin tube 50mm damper on both the air and spring cars. The pictures below show the adjustable 2.5" spring perch I got from Koni and there is a link to a Bilstein damper from Turner with what appears to be a removable perch that mounts on a clip similar to that on the Tesla dampers.
If the perch does sit on the clip on the coil spring cars then the whole issue of ride height may have just gotten very easy. Originally, I was thinking I was going to have to have springs made to the correct dimensions to provide the ride hieght I was looking for. With removeable perches, it may be possible to replace the existing perch with one set to the desired ride height or with an adjustable one. I think it is time to disassemble my wife's car which means giving up mine for a while
+1 I'm good with ~1 degree of camber reductionI'm going to drop the next batch of ten camber links off for machining. My first pass parts took about a degree out of an air suspension car's rear camber. Does this number still seem like the right one for everyone?
I'm working off the idea that my -2.2 or so went to -1.2 with the links which is almost exactly what my wife's S85 has on coil springs.
I dug up the details of a very old project i did... where I worked with a company to design/build height adjustable spring perches on stock shocks... and I had forgotten about all the effort needed to make a street-able kit, i.e. all things NVH. We had to add bushings between the spring and the lower perch, design a new upper mount, w/new bushings, new bump stop, etc.I think custom lower perches and keeping everything else would be much smarter unless you absolutely needed adjustability. Perhaps adjustability could be accomplished with shims in the custom lower perches.
Thoughts?
Understand the arguments about a release of liability, but HMO, something is better than nothing. Something simple stating exactly what you're providing: experimental parts, not approved by anyone, buyer assumes the entire responsibility and liability. Buyer must sign... even ask us to get the form notarized - if that provides more protection.I need a little help with this whole camber link thing. Specifically, I am all for a forum based effort to generate helpful parts. I'm not in the business, nor do I want to be, of making parts but I do not mind helpful projects for the greater good of the MS community.
S60 Coil SpringAll measurements are in
Left Front Right Front
Left Rear Right Rear
