You did say it was only an hour away from your house, so I figured the 70kW is just the natural tapering of the charge speed based on your existing level of energy in your battery. Yes, you can get over 100kW when your battery is nearly empty, but it's going to be down to 20kW and 10kW and less when it's almost full, and it's a nearly linear progression all the way through.I believe I was around 50%. No other cars at all.
Here's a handy rule of thumb to see if your charging speed is about normal due to tapering or whether something is artificially slowing it down. Add together your state of charge in percent and the kW power level. Those two added together should be somewhere near 120, plus or minus maybe 5-7 because it's not strictly linear the whole way. In your case, you had 50% + 70 kW, so it was dead on at 120 and totally normal.
That is great that you were able to get a dryer outlet adapter made. What exactly is it adapting to? If it goes from the official Tesla 14-50 on your mobile charge cable to a dryer plug (10-30 or 14-30), just keep in mind that the Tesla charging system cannot detect that you're adapting to a 30A circuit. Turn the charging rate in the car down to 24A or less to have the proper load for a 30A circuit like that. But if you've built your adapter cable from the Tesla 14-30 to a 10-30, that is already at the proper circuit rating, so it will automatically set that 24A limit for you.
