They should but it has been over a month since I initially brought the vehicle in and I still haven't gotten an answer on that one.Tesla should be able to pull up your logs and determine why that 16 miles of range was inaccurate.
The car said we had 16 miles left and we weren't driving 75mph for the previous 15 miles before the battery failed.
There in reveals the problem that Tesla is very vague in the Warranty in regards to degradation for the Model S and Model X unlike what they have written for the model 3.
I will reiterate that we didn't have the heat on.
We are just trying to get details on what actually happened.
It sounds like you are saying that you were accelerating when the car shutdown, is that right?
You keep saying "but the car said we had 16 miles" when you know that that is an estimate and not entirely accurate. Your usage shows that that 16 miles should have lasted about 12 miles. (Based on 22% higher usage than is used for the rated range remaining.)
They aren't vague at all. They explicitly say it is not covered period. For the Model 3 they decided to cover degradation but only with 30%, or more, degradation. So if the S&X warranty was the same as the Model 3 you still wouldn't qualify for a warranty replacement. (Since you are only at about 21% degradation.)
Then why have others received a new battery with 21% or less and they have already told me they aren't going to cover the battery. Therefore they can just tell you what they want and you are exactly right(they don't cover degradation for the Model S or X) but will for the Model 3 when you pay about twice as much for the S or X. Thank you for allowing me to show others about how unfair this is. I am sure you would feel differently if it happened to you.We are just trying to get details on what actually happened.
While they were looking at your battery issue did you have them replace the screen on your MCU? (Since it looks like it is leaking goo into your car while leaving the bubble around the screen.)
noWhile they were looking at your battery issue did you have them replace the screen on your MCU? (Since it looks like it is leaking goo into your car while leaving the bubble around the screen.)
NOT ON MY 2012 BECAUSE IT WAS GOING TO COST OVER $1000 DOLLARS BUT THEY DID REPLACE ON THE 2018 ALREADY BECAUSE IT WAS UNDER WARRANTY. THANKS FOR BRINGING UP ANOTHER PROBLEM ON A CAR THAT IS ADVERTISED AS ALMOST MAINTENANCE FREE. I HAVE SPENT OVER $20000 DOLLARS ON THE 2012 SINCE I PURCHASED IN 2013 ON MAINTENANCE, DOOR HANDLES, WHEELS THAT HAVE CRACKED, ETC.It will cost extra because the warranty has passed.
In addition, as Tesla said with a yellow border, it's just "cosmetic anomaly which has no impact on performance or reliability of the touchscreen."
...Then why
...not because of degradation, or a hardware failure, but because the software...
They aren't vague at all. They explicitly say it is not covered period. For the Model 3 they decided to cover degradation but only with 30%, or more, degradation. (And not unlimited mileage only to 100k/120k miles.) So if the S&X warranty was the same as the Model 3 you still wouldn't qualify for a warranty replacement on two fronts. (Since you are only at about 21% degradation and past the 120k mile limit.)
Your exactly right. I wish Tesla could interject explain why the car stopped with 16 miles left with the range indicator and only got 139 miles even when including the driving conditions/consumption. It has been over a month and I still haven’t got a straight answer from them.Problem is that the forum readers have no way of knowing what is going on. Only one side of the disagreement.
Thanks for information. I will give it a shot.@HMARTINPT,
The fact that you drove 139 miles and the battery died with 16 miles left is much less important than the fact that you are getting 209 miles rated range at 100% in an S85. You should talk about the 209 miles rated range at 100% and show screenshots of that and skip the other details.
209 miles at 100% is unusual. However, achieving less than rated range in an S85 is very common and is the default. The car shutting down before range drops to zero is also common. See Bjorn's tweet here. Those are unimportant side topics. You are distracting from the main issue with irrelevant details. Consumption related details are not important here. The important thing is your rated range at 100%.
If you present the issue as "my car consumes too much energy", you will get silly responses like "drive slower". However, this is 100% irrelevant. Your issue is heavy battery degradation. The discussion should be about whether there is a hardware issue or whether this is normal degradation.
Btw, I don't know why you quoted me in message #81. I don't see how my message is related to your response there.
OP had mentioned earlier that he charged to 100% for this trip and showed 209 range rated milesNew was ~77.5 kWh usable, if you charged to 90% to get 50 kWh usable charging to 100% would give you more like 55 kWh usable. 55/77.5 = ~72.8% SOH (very rough math not accurate but shown for comparison purposes).
I think we all agree that we can't compare a Nissan Leaf to a Tesla Model S. That is why I was willing to fork out at least 2-3 times the money to get a Tesla and the 8 year infinite mile warranty. If you did compare I guess you could say that I could have bought almost 3 Nissan Leafs during that same period for the same amount of money.note, I'm not refuting your entire claim put forth in this thread, you may be perfectly right that you have a need for a replacement pack for it shutting down before hitting near 0 miles left but,
I see 50 kWh used on a trip which considering a 90% charge is not terrible vs Calculate usable battery capacity based on rated miles values
Most EVs with capacity based warranties wouldn't be replacing the pack yet based on that capacity loss. Nissan (the most common non Tesla EV being the Leaf) won't replace a pack until it drops below 66.25% SOH. Some companies will do it at 70%, Chevy Bolt waits until 60%.
So for sure look into the premature shut down. Get the pack replaced for free if you can. But don't begrudge the capacity loss in general. In southern Texas you would be losing something like 15% a year in a 2012 Nissan Leaf (you'd have gotten a free battery at year 2 or 3 and have needed another at year 5 most likely out of warranty, and be down a very good chunk on your 3rd pack that would certainly be out of warranty).
Tesla cools the pack better, and I hope they give you better warranty protection, but by the capacity loss alone they don't have to.
The 139 miles is perfectly consistent with all the information on your screen shot and the information you provided. What doesn't make sense is why it died with 16 miles remaining. Did it give you any warning before it died, like slow down, or any kind of indication? You say Tesla hasn't given you a straight answer, so what did they say? Are you still driving the car right now?Your exactly right. I wish Tesla could interject explain why the car stopped with 16 miles left with the range indicator and only got 139 miles even when including the driving conditions/consumption. It has been over a month and I still haven’t got a straight answer from them.
