I'm comparing the "Current drive" statistics having driven 10km with energy app consumption for the last 10km
Should be the same, but.... it's almost like a km-miles conversion (1.6) although both values should be in km
At 30 km, trip computer says I used 5kWh, at 157Wh/km, which sounds correct
Energy app says I used in 30km 6% battery which sounds correct
Energy app says in the past 25km energy usage was 247Wh/km
So 247Wh/km * 30km =7.4kWh. But that is 6% battery.
So that corresponds to a 7.4kWh / 6 * 100 = 123kWh battery at 100%
So there is obvious an error somewhere!
Lack of significant digits as well as the different calculation update cycles across the different screens prevent appropriate comparisons when looking at short distances traveled.
The odd numbered releases are on a different build and may not catch up for a while. I believe they are for new cars. Eventually you get on the regular build cycle and you'll get the fix. It's an annoying bug but not critical. The other energy screens are correct and give a better view anyway, although I've used this one more myself.
