What about an in-wall EVSE w/ a reel for the charge cable on the ceiling?
Problem is that a coiled warm cable becomes a hot crispy cable.What about an in-wall EVSE w/ a reel for the charge cable on the ceiling?
Remember that whatever you do, you can put in bigger wire than you need. Code allows for you to put a smaller breaker than the wire can handle, just as long as the breaker matches what the other end wants. So if you put in a Nema 14-50 and a 50 amp breaker, instead of putting in 8 AWG wire, put in the fattest wire you can physically put into the attachment points - at least 4 AWG wire. This will let you trivially upgrade later by changing the breaker and what you have at the other end.
While you are installing the electrical drops, be sure to install a CAT-5e or better network drop too. A lot of the home chargers (e.g. blink) are network capable. Yes, they can usually do wifi, but it's more reliable to go with a wired network for fixed installs.
Also great advice. I have them putting CAT-5 in almost every room of the house, but didn't even think of the garage.
( What EVSE would need to upload or download quicker than 100mbit/s ?)
You want to run CAT-5 or better because it can be used for lots of other things that you won't think of at time of install. CAT-5/5e/6 can be used for:network, telephone,alarm, rs-233,rs-485,HDMI,audio,video,remote power,electric gates, door bells, etc. Installing cat-5 to places where you are doing stuff gives you the flexibility to install something new using the existing cat-5 cable. Two rules: 1) when in doubt run two CAT-5/5e/6 cables. 2) you can never have too much slack.( What EVSE would need to upload or download quicker than 100mbit/s ?)
Cat5 shouldn't even be considered. JMO.
Right, its Cat5e. I don't usually specify the "e". As you said, there's really no point in installing regular Cat5 at all, so we don't even distinguish between them anymore in my field. Its just understood that if you say Cat5 you are referring to Cat5e.
