On the CAMCO 14-50, I just did not insert the neutral blade, is has no purpose when used as an adapter on a 6-50, since a 6-50 is just 2 hots and the ground. I think you can get away with 50 feet or so, but you should probably build it as 2 cords, maybe (2) 25 footers, or a 15' and a 35', as it's always better to use the shortest possible extension that works.
To build a 6-50 extension cord, you only need 6/3 SOOW, if you are building a 14-50 extension cord, you would need 6/4. (For the neutral conductor).
Personally I wanted the lowest weight cord, that's why I went with the 6-50 and built the RV Park 14-50 to 6-50 short adapter cable; I can still use a 14-50 in the wild, I just don't need to carry %25 more weight on the extension cord cabling... I also bought the matching 6-50 UMC adapter as well, of course.
I see that, my question was more in using the NEMA 14-50 in a NEMA 14-30 outlet which also has a neutral wire, but a different shaped prong so they don't mate properly, but would if the neutral prong is removed.
