JRP3
Hyperactive Member
Loads of mixed packages might average out, but dedicated loads of single products would certainly have different densities, i.e. pillows vs barbells.
I look at it another way... Diesel fuel is slightly more energy dense than gasoline. Or, 40.7 kWh per gallon. If one gallon of diesel will move the vehicle 6 miles, that is equivalent to 6,783 Wh per mile energy consumption. Electric vehicles are far more energy efficient. So it would take less energy to move the same distance in an EV powered truck. If you presume that a diesel system is 38% efficient (they aren't) and the EV were 90% efficient... That means of the 6,783 Wh expended per mile for the diesel, only 2,577 Wh were used for actual motive force. So, an EV would need to have 2,864 Wh of available energy to travel one mile with the same load. Thus, in order to get a range of 600 miles, you need a bit over 1,700 kWh of battery storage. In practice, you'd probably end up with four separate 400 kWh battery packs. Yes, they would be much heavier than the diesel fuel, and yes, their weight isn't going to drop 99.9% as electrons are 'burned'... So you always have to carry the 'extra' weight around with you, but that is no big deal. How much would they weigh? Idunno. But I suspect it would be nowhere near the 12,500 lbs per axle limit.Use your imagination. A 3500 lb 5-passenger car manages to carry about 900 lb of cargo (passengers and luggage) about 25 miles on one gallon of gasoline. Vehicle weight to cargo ratio = 3.9 : 1
A 4500 lb Tesla carries the same load the same distance on about 10 kWh of power, using a 1200lb 85 kWh battery. Vehicle weight to cargo ratio = 5 : 1
A loaded truck & trailer weighs about 80,000 lb and carries a 40,000 lb payload 25 miles on about 4 gallons of diesel. Vehicle weight to cargo ratio = 1 : 1
How big would that electric truck's battery have to be to deliver enough power? Bear in mind that the legal weight limit per axle is 12,500 lb, so battery weight has to displace cargo weight (so does fuel in a diesel, but 250 miles worth of diesel weighs just 264 lb. on a vehicle 16 times as heavy as Model S.
Here, I'll help with that...Tesla semis mentioned in master plan 2, BOOM!
I think this is where the notion of battery swap comes to fruition. If someone really does need to 'hit the road' immediately, that would do the trick. Supercharging could still add 50% in half an hour, and in the big wide, open spaces along US roads, solar power with battery backup would be superb.I think the hardest part will be delivering enough electricity to truck stops to charge 30-50 trucks at once at 500kW each.
OK. We'll call it a 'perpetual stopping machine' instead. Because what you describe amounts to driving with the front brakes on all the time.Not Perpetual motion because only 1 motor charging/supplementing 2 motors using, eg your using more than you can generate thus needing to recharge at some point.
Or even exclusively available at Tesla Depot locations that are EV Specific...?A 600kW unit should juice the T300 up to 80% in roughly 20 minutes. Introduced in strategic alliance with [gas station company] for deployment along all major transportation routes.
Tesla Motors is a fan of competition. Elon Musk that healthy competition is essential to growth. He stated so long ago, and reiterated many times since. Especially after opening Tesla's patents.So will Tesla buy Nikola Motor or hire their people or just allow competition to flourish?
One more thing to consider is fuel used at idle while on break. The average is 1-1.5 gallons per hour. This is probably 9 hours out of the 10 hour break. An electric truck wouldn't need Diesel Exhaust Fluid, which is currently more expensive per gallon than the diesel itself. 1 gallon per 300 or so miles times the life of a truck 1.5-2 million miles.So using 9.3 mpg and 500 miles that's 54 gallons of diesel, using 40kWh of energy per gallon that's 2160kWh, x 35% efficiency = 756 kWh of energy actually put into motion. We'll add 10% to that for buffer and EV drive losses which gives a 831 kWh pack. 756 kWh available would mean 500 miles at 1512 Wh/mi.
Battery swapping makes even less sense for large vehicles then it does for passenger vehicles...
Besides, it won't be needed at all as large batteries charge super fast. My feeling is these will be coupled with a new type of Supercharger intended for commercial vehicles - the SuperDupercharger
Such is the layman wisdom.The more you use quick charging the more quickly it will come near to replacement.
True enough... But there is the phrase 'Super fast charge' used at the beginning of the post. Something tells me that charging two, four, or eight times as quickly as Superchargers currently operate will develop... issues, and stuff. When it comes to longevity and durability of battery cells.Such is the layman wisdom.
Experimental data does not uphold it.
So, let's say 1.5kWh/mi, driving at 70mph, for 11 hours of 14.
