Do you have a dedicated outlet near the parking space? That's where the outlet is the only thing on the breaker, or perhaps where you can remove all other outlets on that breaker without much burden? If so, do the following or pay an electrician a fairly small amount to do the following. This is for a 15a circuit, but if you are lucky enough to have a dedicated 20a (It will have a plug with a T-blade and 20a breaker) that's even better.
- Confirm your wire is rated for 240v. It almost always is rated for much more like 600v
- Put a 6-15R plug on the end (or if lucky, a 6-20R) This is 240v 15a
- Replace the breaker with a 2-pole 240v breaker and connect the former live and neutral to the two hots of the breaker
- Double check that there was no other plug on that circuit. Make sure all other plugs are on and 120v while this breaker was off. (Do that first, actually, but double check.)
- Buy the 6-15P plug for your Tesla Mobile Connector. (Alternate plan, hardwire this into Tesla Wall Connector.)
Yes, that's only 2.8kw. Many people find that the 1.4kw of Level 1 is actually enough, though nobody believes it until they try it. But 2.8kw? (or 3.8kw at 20a?) It's actually way more than enough for all but the most heavy duty drivers. 2.8kw will add 120 miles of range to your model 3 from 9pm to 8am. Even if you start at midnight it's fine, and you get even more on days you don't commute. Yes, there will be days where you drive more than 120 miles, and so you won't get totally full that night. That's not a big deal -- a lot of people don't even bother plugging in every night because you have a big battery and you can handle it.
Wait, won't there be some day when I drive a lot one day, come home and have to drive the full range of the car the next day? Yup. For most people that will happen only a couple times a year. And guess what, if you are driving that far you are sure to pass a supercharger. So go to the supercharger a few times a year. It costs a bit more money but is WAY less than the cost of pulling new wire.
There are a few folks who can't work with this. They drive their cars 50,000 miles a year. But the average person drives under 40 miles/day. Your big battery gives you the freedom to handle some days being more and some being less and still get by fine.
The change described above is very cheap. It's just a small amount of time for your electrician and many people can DIY. Running new wires through walls is great if you can do that cheap, but if you can't, do this. Or even see how well you can do with Level 1 or 20a Level 1. I went for 2 years on 20a Level 1 and visited the supercharger once in those 2 years. It actually works. If you have charging at work it's even easier.
