But then can you slide it u der the passenger seat?
Yes, the DSP is tiny
Ok I am in the DSP settings, but these instructions are hurting my head! Hoping to put together a tutorial, or at least get the DSP settings correct to provide an output file for others to import. Anyone get the settings in the DSP right yet?
Do you have any pictures of the DSP before or after install? Or even dimensions?Yes, the DSP is tiny
I just finished the installation and only got sound coming from the Hansshow rear speakers! Any idea?DSP is only 5"x8.5"x2" tall:
How it looks under the seat:View attachment 608413
Can barely see it. Once the seat is back, the rear passenger won't kick it. Velcro tape will secure it.
We couldn't figure it out either but it's clear that it's a custom profile and the inputs and outputs need to be reversed. Good luck.
Looking to get one of these as well. Leaning towards version A. I have a June 2020 without rear speakers (checked the plug and only have two wires, and I don’t mind the sound stage so a DSP is really needed by me.
Confirming though, version A comes with the sub, amp, wiring for the sub and amp, and also the wires to connect the other speakers?
Thoughts on version A for my needs as well? Thanks all!
You mean Version B? Version A only has self amplified subwoofer and NO DSP.
Oh yeah, one connection was not completely in. So the sound comes from all speakers now but very little from the sub. Wonder why? What position did you set on the sub: Phase 180 or 0 and Autostart ON or OFF?Check that ALL of your connections click in securely!
I have figured out the profiles to reverse the fader and balance however there are still some odd things going on. When I fade front left or right ALL of the bass activates and sounds pretty good, however, the sound profile isn't balanced then. If I move back to the center, the music is coming out of all of the speakers like it should, but there isn't much kick to the system. Very close. I have recorded a bunch of things that I have done and am going to attempt a video to try and help out.
Alright so I got the new version E that has the 31 channel DSP ...
