Yes, it's very straightforward. You just need a "60A circuit" ideally, but it can be less if practical.
Unfortunately, electricians don't always know how to do their jobs so yeah, you do need to make yourself "aware". For example:
- No GFCI is needed/advised
- No disconnect is needed/advised
- No neutral is needed - for Romex runs look for terms like "6/2" or "4/2", not "6/3" or "4/3", or for conduit runs there should be 2 conductors plus ground, not 3 plus ground.
- 50A is fine in many cases and is especially compelling if 6/2 Romex is preferably over a conduit run. Often electricians will just fixate on the "60A" maximum and perhaps sell you much more than you really need. There's sometimes big jump in cost between 50A and 60A.
- Electricians tend to be very conservative as they don't want you complaining that your lights dim when the A/C kicks on. Be aware that they may try to persuade you to upgrade your whole main panel for this and it's almost always unnecessary.
- Consider Romex. If the electrician's plan sounds convoluted, expensive, and unattractive, ask if "6/2 Romex" would simplify the job by allowing the wires to be run loose thru the attic and walls instead. Or "4/2 Romex" if you want the full 60A capacity for a 48A charge rate.
