@scottm, Your stuff is not true. The rated miles number does not do anything at all that is related to anyone's driving patterns. It is a direct translation of the % number by a fixed rate constant, so it is exactly the same amount of accuracy. If you want to be technical, it would have MORE precision available, because it's using a scale of about 0 to 250 instead of only 0 to 100, so there would be less rounding off in the rated miles number.
Oh, I stand corrected then. I thought *ideal* range was that simple translation to some fantasy metric of consumption and rated range (I called it estimated range) accommodated for actual driving distances expected under currently sampled conditions based on past experiences (e.g. learning).
Anyway, I set my display on % SOC years ago and haven't looked back. I like it because for sure it's only looking at the battery and trying to determine what charge is left.
Here's the thing: How I use the charge is up to me. How far I go depends mostly on how I drive and ambient temperature. I only get concerned when (I navigate) my round trip says I'll need more than 2/3 of what I've got left to make the trip. e.g. got 30%, trip says I'll use 20% round trip, leaving 10% round trip.. fine. Depart. Safe to charge at home upon return. That's my "commuter rule of thumb". My highway trip follows different rules: charge every time on every leg, because my SC are spaced out quite far.
Both of the distance estimate settings are always wrong and tick by faster than "they should", and tick by faster than SOC, which is like a promise (hope) broken every time and amplifies the awareness of depletion... which is a mental setup for inducing more anxiety.
SOC never lies. Or at least, it tries hard not to.. and doesn't "project" on your behalf. This is my point.
I would probably be happy with a battery gauge
on the dash that was simply marked off in 8ths and didn't show down to the 1% resolution. Yet, everywhere else in the software and navigation etc.. did show increments of 1%..
