MikeK
R#129, TSLA shareholder
I had a factory tour today with my friend, as he picked up his gorgeous Signature Performance car. I was able to see a completed front fascia that was not mounted on a car. There's not a lot of metal framework behind the fascia, which is good news. The bad news is that there's tons of wire loom, actuators for the cooling intakes, and so forth behind there.
I think it may be difficult to mount the sensor in the "bumper" area of the front (and if you could, it might be a problem anyway because the license plate will extend up into that area).
The maybe-good news is that the very lowest painted part of the fascia, below the lower grille opening, appears to be a continuous piece all the way across, and there are few or no obstructions back there. I'm not sure whether the sensor would pick up a car in front of you if you mounted it that low, but if so, it seems like the path of least resistance.
One other thing: the black plastic fairings that dress up the borders of the frunk are removable. This gives a fair amount of access to the upper area behind the grille. It's probably not the access you'd need to mount the sensor unless you only wanted to mount in the area of the nose cone, but it should at least give you a vantage point to inspect the back and plan where you will put it.
(No photos allowed in the factory, sorry!)
