I had a Zappi 2 installed a few weeks ago, all seemed fine initially but over time I've noticed that the charge rate is very up and down, normally it hasn't presented too much of a problem but in the last few days I've had cause to need to charge to a higher level and due to the current fluctuation the charge hasn't reached the required level. Hopefully, you can see what I mean from this screenshot showing the typical fluctuations happening. I'm assuming this isn't normal behavior for the Zappi and that I should be getting 32amp throughout? Just for context, the amps are bouncing around from 16-32 and the kw delivered are from 4-7kwh.
Any thoughts as to what I can check myself before having to call the installer?
TIA
TIA
