Yes. I do. :smile:That's what I was hoping it might be for, but I see nothing in the spec sheet regarding it. Do you know what sort of control stimulus you apply to this line in order to call for the contact closure? If I remember right (I don't have the gfci in front of me right now) the unit has 2 line inputs and 2 line outputs. So I would sort of presume that the only natural thing to expect would be that applying ground to the red control might close the relay? That would be a pretty simple way for the device to work, as it would just require a 120V relay coil inside.
Do you know Scott?
There's nothing in the spec sheet because I believe this GFI was a custom version for Tesla. I believe that they separated out one of the power leads to the GFI control circuitry. This way they could turn the GFI on/off.
My first mc240 went bad a few months after I got my roadster. The red wire connects to an expensive Solid state relay (actually it's a optically connected triac). Mine smoked for whatever reason, so I just connected the red wire to one of the L1 or L2 pins. It may be a specific L1 or L2 based on how the GFI is wired. I would try the Lx that is red. IIRC the control voltage is 240V not 120V. I believe this is because the MC240 has no neutral pin so the only voltage you can get is 240V. Connecting a load between Hot and ground to get 120V would be a violation of NEC code.
