Wiki Everything you wanted to know about Intelligent Octopus But Were Afraid To Ask
Why write this post?
A lot of people are starting to get interested in IO. I don't think Octopus do a very good job of spelling out the benefits in their website. They have some FAQs, but the same questions keep coming up over and over on the forums.
What is it?
In a nutshell, IO is a split tariff that gives you a cheap off-peak rate for charging your EV and other electrical items in the household, including home batteries.
Isn’t that the same as Octopus Go or Go Faster?
The principle is the same, but in exchange for some benefits which we’ll explain, you allow Octopus to control the timing of your EV charge, so they can choose low carbon intensity and/or cheap wholesale priced time slots.
So I’m not in control of my charge? I don’t like the sound of that!
Well yes…and no. You’re in control of how much to charge and when you want the car to be ready, just like you would be normally. Within those parameters, you’re allowing Octopus to control which half-hour slots the car chooses to get to that target % charge. And you can always override IO if you want to “bump charge” through the day.
OK, but what are the benefits you mentioned for this trade off?
First of all, you get a larger guaranteed off-peak window for using household appliances and charging home batteries, etc. It’s six hours between 23:30-05:30. Go, for example, is a fixed 4 hour window.
In addition, when IO schedules your EV charging slots it sometimes creates schedules that fall outside of the fixed, six hour window. If that happens your EV charging and all your household use in these extra-slots is also charged at off-peak rates.
I have frequently had schedules give me seven or more hours of off-peak rates. On one occasion, I had a total of ten hours of off-peak rates.
Am I eligible?
You need a smart meter and a compatible car and/or charger. Since you’re reading this here, I assume you’ve got or are thinking of getting a Tesla. IO works with the Tesla API to create the charging schedules. The advantage of this is that IO will work with any* home charger. If you have a charger with smart features, you need to disable them so that the charger acts as a dumb switch. IO will control everything via Tesla’s API to start and stop your charging.
*Even your granny charger - but you need to tell IO what the max throughput is when you go through setup so that it can work out your schedules properly.
Some of this sounds too good to be true.
Phantom drain caused by having smart charging enabled in the Octopus app has been fixed as of 30th August 2022. One small side effect appears to be that schedules sometimes take longer to appear in the app after plugging in.
Further questions (to be updated in the main thread body once the edit timer on this post expires)
I have two EVs, can I charge the other while on IO?
Not with IO scheduling the charging, but you can charge any other car in the fixed 23:30-05:30 off peak window or at any other time at peak prices.
What are the rates etc?
Octopus do a decent job of explaining the peak and off-peak rates along with contracts etc. Head over to their pages to discover that.
I asked for a target % of x, but I got less than x.
There are two or three reasons for this.
The first, most common reason, is that Tesla reports battery % differently depending on where you look. The API (that IO uses) reports the gross battery %. This is generally fixed but can fluctuate very slightly. The Tesla app shows usable %. Apps like Teslamate and Teslafi can display both. Quite often, there is a delta of 2-3% which may be down to battery temp or other factors. This usable % will often be recovered as the battery warms up during a drive.
Some users have reported charging % being way off, perhaps 10% or more. This could be down to an error in the onboarding process. Some of the charger database entries incorrectly assume the charger you are onboarding is the 11kW version, without actually saying so in the charger description. The Andersen A2 was an early example of this. If you suspect this may be the case, the easiest thing to do is go through the on-boarding again and choose "Generic 7.4kW charger". It won't affect your functionality on IO in any way.
Lastly, it has to be mentioned that occasionally IO just craps out. It may be down to a comms error, a server error at Octopus' end, or just reasons. IO is a beta product and it's wise to expect one or two quirks from time to time
Not sure how you're doing the maths on this, but I believe you're leaving out the charge cost?
Assuming a 260kWh/mi efficiency, 25 miles of EV = 6.5kWh/day. In addition to your household usage of 8, that's 14.5kWh of usage.
At today's tracker price of 18.5p, that's £2.68.
With IO, assuming the blended daily rate at 23p/kWh for household consumption (18h of day rate at 31p + 6h of off-peak at 7.5p), and those 6.5 kWh of EV charge at off-peak, that's £2.34p
So IO would be cheaper for your mileage until Tracker falls at 16p/kWh or under.
(Of course I'm assuming constant usage during the day for IO, more savings if your can time shift, but less if you run your big appliances at max day rate...)
Here's my working out:
Tracker @ 18p
Intelligent @ 31p day + 7.5p night
Household usage of 8kWh
EV usage of 6.25kWh (assumption of 25miles per day at 4miles per kWh efficiency)
Tracker comes in at £2.57 daily & IO comes in at £2.97 daily - these costs exclude standing charges (41p and 45p respectively) We could potentially move the dishwasher and washing machine to come on at 11:30pm to take advantage of the cheap(er) IO rate; just gotta figure out if we can set up timers on those.
Tracker should work out about 10-20% cheaper than Agile for me. I do very little mileage at the moment due to working from home, so my peak use is higher than my off peak car charging would offset. Even if I min/max the cheaper periods on Agile for things like washing machine, dishwasher etc it doesn't make enough difference. IO, Go etc don't even come close due to the much higher daytime rates. Also Tracker takes away the need to micro manage around the high evening peak on Agile. Gas is a no-brainer unless you're somehow on a legacy tariff of some kind.
Heads up if you need to contact Octopus about any kind of switching, I would suggest using Twitter. Only my electricity was switched to Tracker at the weekend but I'd opted in to switch both. I tweeted them to ask the status of my gas switch & got a reply in 7 minutes that my gas tariff had been updated to Tracker as requested...
I could do that but doesn’t that go against the spirit of IO? It is a better deal than Go for sure.
As has been mentioned already, the T&Cs only say you need to do one smart charge per month. You’ll only get the standard 6 hours off-peak so won’t benefit from extra slots. What I don’t think is in the spirit of IO is when people intentionally lower their charge rates to generate more charging slots. This latter behaviour is likely to lead to clamping down of the tariff.
agree. It woudl be good if octopus worked with the big battery manufacturers to be able to avoid draining during extra slots on IO but until then I don't see an issue with you choosing to mitigate that through reduced usage of the IO controlled charging
They are working with battery manufacturers to integrate their control into the slots. It won't include Tesla Powerwall though as they don't release their API for public consumption.
Yes, that was my understanding. Although they did have the TEP so there is some hope that maybe they'll be able to integrate IO and Powerwall in the future. All fingers crossed!
Thanks @Cardo i missed that bit in the T&C’s. I can manage plenty of night charges in winter, but none or very rarely in summer.
The reality is I’d be spending about 1p per kWh to buy in at night versus export during the day. I’d probably buy 10kWh per month in summer to show willing. The cost is insignificant but it would make my grid use stats look awful 😂. April to September is just about 20KWh max!
2.4.5 To be eligible for this tariff, you agree to download the Octopus Energy app and register your low carbon technology on the app. This is an ongoing requirement throughout your time on this tariff. If at any time you do not have an active authorisation for integration with a supported vehicle or charge point and you have not had such active authorisation for a period of more than 30 days, you will no longer be eligible for this tariff and we will switch you to one of our fairly priced standard tariffs and you will be billed according to your usage under that tariff.
The nit-picky part is what specifically do they mean by “active authorisation?” Does it just mean having a car linked to the account, or enabling smart charge?
Reactions: Dilly
I’ve emailed for clarification
What if you have a a granny charger for your Tesla and a fast charger for your other EV that is not-compatible with IO? ;)
Do explain the physics behind that. Lower current, lower temperature/resistance, higher performance of AC-DC transformer, no?
I actually think in practice is some kind of bell curve, but the Model 3 (at least) doesn't do great at low current AC. High DC current is something else.
