Can't you get a convex stick-on mirror at any auto parts store? What makes this one worth $154?
Id also like to be able to adjust the camber (with shims) like you can on an actual lotus. You are unable to do this on the roadster as this part was changed for some reason.
I'd say you got some bad advice about the shims. I have the adjustable suspension and use shims to adjust the camber and I'm reasonably certain you can do the same thing on the standard suspension. I got my shims from Tesla but they are the same as the Lotus Elise.Personally id like ceramic bearings to improve the efficiency of the car. Id also like to be able to adjust the camber (with shims) like you can on an actual lotus. You are unable to do this on the roadster as this part was changed for some reason. Id like to know what the tyres were that tesla were going to recommend for the 3.0 upgrade but didn't.
I worry about using a lithium battery in my climate. It can go months below freezing so the battery would have to heat itself in order to recharge. Any benefit from weight savings would be given up in heat losses.I also recommend replacing the 12V battery on the car for the one i have here. Its been working excellent since i swapped it. 12v battery service required, can it be replaced with lithium? | Page 2 | Speak EV - Electric Car Forums
Also add weather stripping to the bottom of the doors to keep the road crap from the sills.
So in conclusion, what I should be looking for is:
Xenon headlights - 2600 $ (Tesla)
Hardtop - 5000 $ (Tesla)
Winter tire set - 4400 $ (Tesla, forged rims)
HPWC and NEMA 14-50 adapter - 2000 $ (Tesla)
Brake upgrade - 300 $ (Carbotech AX6)
Paint armor - 3000 $ (3M)
Aftermarket soundproofing - 2000 $ (Dynamat)
Here's some photos of the under door weather stripping
My BOE's are full convex which I really like, both mirrors have identical lenses so no mix....
What type of fasteners are those? They look like screws, but sometimes they use plastic plugs that look like that. How well does it work? Is the material shaped like an "L" or a 7? Does it keep the gravel from getting in behind the front fender?
What's BOE? British Original Equiptment? Pictures?
