The drivers door still shuts when I walk away.How about closing? If you leave it a bit open and walk-away, does it auto-shut? Does the fob top press open driver door?
It seems like a fob sensing issue maybe.
More likely it is a sensor failure. Ours had to be fixed earlier this year. Actually I just look up my invoice, the part they replaced was called:
Module - Central Body Controller - BCCEN
1045451-00-I
But I have read door sensor for auto present could fail too.
I had this same problem with my brother model X. They changed the BCMThe drivers door still shuts when I walk away.
Double clicked the FOB and the drivers door does open.
So what do you think? Neither FOB opens the door when I walk up to the car, maybe replacing the batteries would help?
Can you tell which sensor exactly? Our X has the same error. Thanks!I got changed a sensor with 2pin connector in a middle of car, reset car from "T" menu, no need to change Central Module. Doors open and close while approaching and leaving.
Do you know if the 1043130-00-B can just be replaced? Or would it require programming?since I had the same issue today I can answer this question:
it is the antenna for keyless entry, there is one in the center console and another in the rocker panel, driver side (and two more in the front and back of the car).. BCCEN_W114_LFAntErrorDriver should be the one in rocker panel (vs BCCEN_W113_LFAntErrorCenter would be the one in center console).. part number is 1043130-00-B and costs under 10$ but it is likely that the antenna itself is fine but BCCEN needs to be replaced
