Dreaded front suspension creaking sound
I had this issue with my 18 M3LR with 80,000 miles living in Texas. Tried greasing it , noise came back after a month. Decided to pay Tesla to do the front upper control arms for $340 total in service. Completed this only to have them also recommend the following front suspension quoting $947 (parts and labour) at the service center, which I couldnt get done same day at service center Oct 11. Well when I made the appt for tomorrow at the other Austin service center the estimate went for exact same parts/estimate went up from $947 to $1484. I have an appointment and at this point pretty upset that Tesla is apparently charging me double the unit price for each part. I asked it be escalated to manager who said we cant honor the 1 week old price. I am going to probably just buy parts online and have a local shop do the work. Had a lot of faith and comfort in always taking it to Service center but guess need to shop around sometimes.
Notes from estimate:
During in service, noticed that front suspension lateral links (both sides) bushings are worn out and front suspension compliance lower links (both sides) are worn out, as well
Correction: Links - Compliance - Lower -Front - RH/LH (Remove and Replace) -Remove and ReplacePriceAdjustmentSubtotal116.100.00116.10
Parts Replaced or AddedPartQuantityUnit PricePriceAdjustmentSubtotalNUT&WSHR[SW],M14X1.5,[10],ZNFL,PTP(1109263-00-B)2.003.567.120.007.12FRONT LOWERCOMPLIANCE LINKASSEMBLY - RIGHTHAND(1044359-00-A)1.00300.39300.390.00300.39FRONT LOWERCOMPLIANCE LINKASSEMBLY - LEFTHAND(1044354-00-A)1.00277.32277.320.00277.32
Parts Subtotal 584.83Correction: Links - Lateral - Lower - Front -LH/RH (Remove & Replace) - Remove andReplacePriceAdjustmentSubtotal103.200.00103.20
Parts Replaced or AddedPartQuantityUnit PricePriceAdjustmentSubtotalLOWER LATERAL LINK- FRONT(1044341-00-D)2.00291.84583.680.00583.68
Parts Subtotal 583.68
1,387.81
Reactions: Scott13TMSP85
I would recommend the Valvoline Full Synthetic Moly Fortified Grey Grease for a lifetime satisfaction. I used it to lubricate the squeaky pulley bearings on my Mercedes using a hypodermic needle and it has not squeaked now for over 3 years now.
Make that 4 years now. The pulleys are still not squeaking. Earlier I had to get them replaced every 2 years.
