m6bigdog
I'm thinking you probably haven't read the whole thread either. If you have, and it was some time ago, I'll remind you of a couple of salient points:
--The Ds are the first models where this is any kind of an issue. Other Model S vehicles had odometers that were much more accurate, and provided the expected figures.
--With all the Ds off by about the same amount, it appeared to us that the problem could be as simple as a bad formula or calculation somewhere. There wasn't variance within the odometers, with all of them reporting wild figures somewhere within 4% of the correct figure. All the D odometers were reporting mileage about .8% longer than it actually was. This is precise and accurate--just wrong.
--Tesla has now corrected the issue on my car. For now, I have the only known car with the fix, but that's probably because I'm the only one who has noticed it. One theory is that the fix has been made in software, but needs a TPMS reset and/or a wheel change to be activated on the car. Another possibility is that the fix somehow has to be taken care of while at a Service Center, as my car was at a SC just before the odometer started reporting accurate mileage, but I don't think this is likely, as there was no documentation on my work order about this.
I think we can stop talking about whether the problem is real or not, who it matters to and why, SAE standards, etc. (since that's all been done before) and at this point just focus on whether or not other vehicles are receiving the fix, and if so, what it takes to trigger it.
FWIW, there is no such thing as an absolutely accurate (<1%) odometer/speedometer when the vehicle tire is used to measure distance or speed.
Why? because all the tire variable that cause an odometers error can be accumulative!
1) the tire wears from the max diameter (10/32" tread depth) when new to a smaller diameter when it is warn-out.
2) the tires rolling diameter is smaller from the measure/designed diameter therefore the tires revolution/mile must be measured on an SAE standard test roller and that is +/- the same tire rolling on a vehicle on the roadway. This all by it self is +3% (814 measured vs 787 calculated) with a Michelin PS2. and the warn-out PS2 calculates to be 2% less than the new tire
3) the rolling distance for any tire manufacture, specific tire size and/or type (19" vs 21", Michelin vs Continental, MXM4 vs PS2) is different even though the tire size is the same.
4) The tire constantly slips on the asphalt/concrete roadway so the actual distance traveled will vary based on constantly changing traction forces such as regen-braking, pedal braking, acceleration, speed, head/tail winds, air density etc.
5) the vehicle drive system RWD, FWD or AWD will change the accuracy because the tire slip is greater on the drive tires so the D models may require a different rolling tire factor than the non-D models.
Therefore, even if every Model S was delivered with a <1% odometer error, tire wear and/or replacement tire would bugger that up in a few thousand miles.
So can Tesla tweak/adapt the Odometer accuracy?
I anticipate they can change the tire rev/mi. factor in the software, but they would need to constantly tweak the rev/mi. factor (at every tire replacement and as the tire wears) based on some assumed more accurate actual distance traveled like the GPS.
What does maintaining a super accurate (<1% error) odometer buy you.
IMHO, just because you can measure it doesn't signify it is useful information, as +/- 1 to 3 mile in 100 is irrelevant for any real useful purpose in the big picture of vehicle dynamics and actual performance.
