Kalud
So this changed somewhere between VIN 5xxx and 25xxx ?
25610 here and having the issue.
Did you have a nano coating on your car or Opti-Coat?
Now that's babying a car - washing with beer!
Ya gotta be careful though. Use too much and the car gets to hopping!Now that's babying a car - washing with beer!
Obviously there is a bolt made from galvanized steel straight through an untreated Alu plate. Also perhaps some other metal in contact? The Alu plate becomes the sacrificial anode.
I think a mod should change the title to remove the "on norwegian cars" part as its a global issue. Probably more important where road salt is used.
Here is a photo peeking down vertically in the the gap just below the front triangular window. Notice all the white oxide on the metal.
Here is a close up of where the mirror attaches to the chassis, where the white oxide is oozing out and running down the side of the car:
yeah us here in the northeastish (NJ/PA/NY/DE/VA) seem to have been continually hammered with snow this winter. woke up to another 4 inches this morning...I think we're breaking records with like 60"+ so far this winter...might be close to the most snow ever record.
Pleasantly surprised that this thread has stayed free of Tesla fanboyism that sometimes plague this forum!
What I`ve learned so far is that a car delivered in Norway in December has the corroding brackets. A car delivered in march -14 has coated brackets.
This means that production changed somewhere around December +/- a month or two. If changes were made around December to production, Tesla must have known since late fall 2013?
It takes time to test and manufacture a different bracket, but once they found the solution and applied it to production, they should`ve also started producing at a high volume dedicated for the service centres as there are roughly 25.000 Model S` driving around with these brackets. Why not start swapping at full speed to prevent the publicity that will arise when spring comes and people are unable to clean their cars…..
Mods: feel free to remove “norwegian” from the title as this is a global issue.
I expect that materials/suppliers change without notice. My old car has none of this Al oxidation. It has suffered two wet, cold, icy, and snowy, salty winters. Tesla needs to be more vigilant about these changes/suppliers.
