BertL
I do not believe it is or ever was going to outside source for album contents. Are the songs that are being stripped off ones with guest artists? Often these are tagged as "frank Sinatra featuring...." and those are always put in separate album unless you edit the album artist tag.
Art will not be recognized unless it is tagged to the track and yet to be nailed down format. We do know 300x300 jpg does work.
Re using tag editor, you need to know exactly what tags to edit, and track sequence needs to be 01, 02 vs 1, 2
Prior to 8.0, assuming it wasn't already cached, I know USB was going out to Gracenotes to find album art, but as @tomas suggests, that's probably all. ...and yes, there is NO ALBUM tagging of some sort... it's all done at the track level, carried along with the audio/video contents in the same file.
In the past, Tesla has used the TRACKARTIST Tag when IMHO ALBUMARTIST would have been a much better decision for trying to quickly access things in a vehicle. Individuals can do their own thing with what's put in any tag, but by convention, ALBUMARTIST should generally represent the primary artist or group for that album. The TRACKARTIST tag can then be used to specify multiple artists on that particular track. If you have a solo album, in theory both tags would be the same. On compilations and say Broadway, TRACKARTIST will be quite different across each track in the album and it's why in the past, a single album would sometimes show up as multiples in the Album view. The further problem becomes for any player, there is no real standard how artist names are separated when their are multiples (comma, semicolon, etc., etc). So while that sort of logic could be attempted like it is say in iTunes to some degree, for simplicity, I'd just be happy if Tesla always used ALBUMARTIST when there is reference to "artist" somewhere in the UI... Further:
- In non-Folder access methods, Tesla has not consistently maintained the combination of (TRACKNUMBER + DISCNUMBER + ALBUMARTIST + ALBUM title) as the sort order for all tracks within the interface. This would have fixed past and present issues with so many anomalies, and Tesla wouldn't even have to use the PARTOFCOMPILATION tag which has it's own set of additional problems and even more inconsistent usage (e.g. there is no formal definition as to what is and is not a true "compilation" even for those that do want to use this optional tag).
- For those that want to use Folder access to their USB media, great, but IMHO the best one can expect for is Tesla to then keep tracks sorted alphanumerically by filename within folder. If Tesla tries to get smart and use some tag data in conjunction with the everyone-is-different-file-structure, well, it's gonna be an inconsistent mess. It's not reasonable to expect Tesla or any other mfgr to read our minds as to what we expect any further than basic alphanumeric directory access in "Folder View".
In case it's helpful to others, while waiting for my MS to come back from the SvC, I have expanded my initial USB test cases to validate:
- Major encoding formats that are/are not supported (M4A lossy, M4A lossless, MP3, AIFF, FLA, FLAC, M4V, MWV unprotected, WAV)
- If Multi-disc sets are handled or not, and how that does or does not continue to cause additional problems with "sequential track playback by album"
- Determine what's going on with TRACKARTIST vs ALBUMARTIST, including where there are multiple artists in a track tag and how that is being represented in the UI
- Several investigative items related to tagging; Which (of what I consider the basic tags an automobile player needs) are and are not used; If any do or don't influence Folder access by filename or not
- Album Art -- simple test with jpg 300x300 on flac/m4A/wav/mp3 to sample if there are issues with art in different encoded formats; more comprehensive tests using m4a lossy with both jpg and png and Front Cover art 300 to1500 on a side in 100 increments; how multiple front covers and/or other art is or is not handled
- Search -- various observations
