Compatibility Question: Temai Cup Holder + AO Center Console Wrap
Just wanted to know if anyone is using the Temai center console cup holder inserts with the Abstract Ocean center console cover, and if so, are there any fitment/compatibility issues? Doesn’t look like there would be but wanted to double check. Thanks.
I have the AO wood console cover, which likely uses the same cutting pattern as the vinyl covers. I’m using a different cup holder. The one you show appears to have a lip that would sit on top of the cover. Shouldn’t be any problem, because the cover material is thin, and is cut to fit flush with the cup holder outline.
Reactions: Killer Junior
