Is it not rather risky to keep the tires at the maximum PSI?
When you actually start driving and the tires warm up, the air will expand and inflate over the maximum pressure, increasing the risk of a blowout.
NO, NO, NO!!! You have two choices:
1. You can put less air in the tire and while driving the flexing of the tire will increase the temperature of the tire which will increase the pressure.
2. You can put adequate air in the tire to start with.
In either case the tire will be at the same pressure after an hour or so of highway driving, however the tire that started out with the lower pressure will be far hotter.
Tires are designed for this, that's why it specifically says "cold inflation pressure".
Blowouts generally occur on tires that aren't inflated enough.
Heat, not pressure, kills tires.
- - - Updated - - -
Got it! But is
this gauge adequate? It was quite a bit less expensive than the Longacres.
I have found that cheap gauges are, well, cheap. I had one that actually fell apart from the vibration in the car. Quality gauges will last a lifetime and can be calibrated.
- - - Updated - - -
I always fill my tires with nitrogen. Makes a big diff with changing temps. When s arrives plan to do the same. Surprise Tesla doesn't do it standard. Heck, my Chevy dealer even does it now. All Porsches, etc have nitro that I've owned.
Nitrogen inflation is mostly a scam. The only reason that temperatures changes make a larger difference is that sometimes straight air isn't dry and the water vapour expands more than gas. I will not go to places that sell nitrogen inflation because they will likely cheat me in some other way too.
There are a few legitimate reasons for nitrogen inflation:
1. Underground vehicles and high altitude airplanes use nitrogen inflation because if a fire breaks out, the air in the tires won't add any oxygen to the fire. (There is already plenty of oxygen above ground, so it's a non-issue for road vehicles.)
2. High end racers use nitrogen because it's dry and they can tune their suspensions to get that extra 1/100th second off the lap time.
3. Low end racers use nitrogen because many small tracks don't have electricity in the pits, and nitrogen is as cheap and safe as any other solution.
