markwj: thank you. I certainly take great heed of your opinion. Very helpful. A follow up question if I may, probably equally as dim as the first - how do you use a BS1343 mobile charger? Can I plug that in at home, at either the 13A plug perhaps dialed down to 10A (or, if not, then a 20A plug I also seem to have outside). Or is it for use in a public charger.
It can be used on any plug it will fit into. One end is a standard HK/UK 3 square pin plug (technically called BS1343 standard - just like in your kettle/tv/whatever). The other end is a connector that plugs into the car. In the cable is a small box of electronics that simply tells the car how much current it can draw. The maximum current limit can also be set in the car but cannot be larger than the limit 'advertised' by the electronics in the cable.
To use it, you plug in both ends (one to wall socket, one to car), and the car starts the charge.
For my roadster, I can use the same BS1343 mobile connector at home or at a public charging station.
The 'charger' is actually in the car. That is the (large) electronics that converts AC power from the wall to DC power in the car's batteries. The things you think of as 'chargers' with cables are really very simple - they just provide the AC power unchanged, plus a signal wire (called the 'pilot') that tells the car what is connected and what is the maximum current the car should use. They don't do any charging or conversion. (The exception is DC fast charging, CHAdeMO or Supercharging, but that is a separate topic).
Tesla also sells a UMC (Universal Mobile Charger) in some markets that have a set of adaptors that connect to a variety of sockets. That is very useful for Europe and USA where they have a large number of different types of socket. That UMC was available for the roadster in HK, but not for the Model S.
mAlso, can you charge a roadster at the usual public charging spots in various public car parks in HK (like the ones in IFC) or, like the Model S, are there only very few compatible chargers in public car parks.
Yes, the roadster can use any of the 1,000+ BS1343 public charging sockets just fine.
The issue is not with the car. The issue is the availability of a connection cable.
For the roadster, the car had a proprietary Tesla connector. So, we were limited to the charging solutions that Tesla provided. A few enterprising hobbyists have engineered their own solutions, but that is not trivial as parts for the connectors were hard to obtain.
For the Tesla Model S, the cars in HK use a European standard connector (a compatible extension to type 2 Mennekes). At launch, Tesla will be supplying a 10A-40A wall mounted connector suitable for this. But, no other offering from Tesla at launch. Tesla also commit to offering a higher-power version (up to 80A) later in 2014. But, as the car connector is standard, owners can source other charging solutions that Tesla won't (currently) provide. For example, there are at least 3 other compatible BS1343 to Mennekes type 2 mobile cables that people have found.
Final comment on the BS1343 problem itself. The socket itself is not really designed for a EV charging. It is designed for simple household / office use. If you plug in a light, it may draw 100watts of power (0.5A at 220V) for several hours. A fan heater perhaps 1,000watts (4A). A kettle perhaps 1,500watts (7A) for just a few minutes. An EV will draw 2,860watts (13A) for the whole night long! As you can see, the load is significantly greater for the EV charging and it is continuous (many hours, non-stop). If the wiring behind the socket is not good, or there are other loads on the same wiring circuit, the wires may get overloaded, overheated, and a fire results.
The HK government department responsible for electrical standards (EMSE) has addressed this with a standard for how to wire a BS1343 socket for EV charging. The cable is rated for 16A, it is dedicated for just EV charging (nothing else on the same circuit), and the circuit breaker is also rated for 16A. They consider it safe for EV charging at up to 13A.
Tesla's problem is that there is no way for an end-user to tell the difference between a BS1343 socket wired for household/workplace use and one wired for EV charging according to EMSE standards. Tesla is also concerned that prolonged (many years) high-volume use of these BS1343 sockets has been shown to visibly damage the socket (cracking, damage to contacts, etc).
The 10A-40A connector Tesla provides is a fantastic solution to home / office charging. The problem is that they currently have no solution for mobile charging.
