...This is a first for me...
Since charging to 100% and letting it sit stresses the battery and accelerates degradation why would you do this?I used that trick and fooled my wife, i set her charge limit to 100% and then I moved it back to 90%. Hee hee
JokingSince charging to 100% and letting it sit stresses the battery and accelerates degradation why would you do this?
Many sources but here is the "bible" of battery info.Do you have a source for this information? Did you mean repeatedly charging to 100% stresses the battery? Why would charging to 100% and letting it sit stress the battery?
Battery University said:...Li-ion does not need to be fully charged as is the case with lead acid, nor is it desirable to do so. In fact, it is better not to fully charge because a high voltage stresses the battery. Choosing a lower voltage threshold or eliminating the saturation charge altogether, prolongs battery life but this reduces the runtime....
does charging to 90% each time cause any harm?
thank you sirHere's a couple of links to threads that have helpful links:
Jeff Dahn's recommendation on long term battery preservation
Battery Charging Best Practices
