A question came up in another post about percentage of battery available for driving. There has been some debate that the 90kWh battery has less capacity for driving than the other battery offerings. I have seen many posts about perceived inadequacy specific to the 90kWh. There doesn't seem to be much evidence to support the claims. So, I decided to pull some data from the teslafi.com site.
The teslafi.com leader board captures the top 20 trips from all user data for each model and battery. The data works well for this purpose because it excludes vampire drain. The data only includes usage when the vehicle is not in "P" or driving. The site treats each leg of driving as a separate trip. All usage is consumed during the trip. The usage during the trip should be in theory very accurate if not exact. In order to be on the leader board you have to achieve the longest drive between stops. This allows for a single consumption period without interruption.
Assumption can be represented that each trip most likely started with a 100% charge. The battery percentage used should be 100% or very close to it. Again, no vampire drain. Usage is representative of all consumed kWhs for any reason; speed, road conditions, weather, a/c, fan, seat heaters.
Results for Model X (% of battery consumed / actual kWh consumed):
60kWh
See attached graphics for the details
60kWh
- 76.79% of 60kWh battery usage / 46.07 kWh consumed
- 75.15% of 75kWh battery / 56.36 kWh consumed
- 79.89% of 90kWh battery / 71.9 kWh consumed
- 76.23% of 100kWh battery / 76.23 kWh consumed
