JeffK
Pre-refresh is in the glove box.Believe that is only for the pre-refresh cars.
You might be thinking of Model X
or the 2015 dual motor (also pre-refresh)
They are all available here: First Responders | Tesla
Yes, they do.Does Tesla still have the 'Rangers' program?
I wish they'd stop doing that. Both my EV Fords had lead batteries and both had to be replaced in less than 3 years.Do we know if the model 3 has a lead acid 12v?
Thanks. I guess I was partially right. I thought the refresh S and X where the same.Pre-refresh is in the glove box.
I'm on my 4th 12v battery in as many years in my Model S (and that's pretty common). I hope they make them more reliable for the 3.
The door locks etc are controlled by the 12V battery. Not sure why you'd want the hassle of disconnecting it for no apparent reason.What happens when the 12v battery dies? Could I just remove it from the circuit when I am not driving?
-Randy
-Randy
Forgive me if this has been mentioned, but why does it matter how bad the 12v battery really is? (For the point of getting in and "starting" the car). As long as the dc/dc inverter is working you should have 12v power. It will be constantly recharging the bad 12v system. So the draw (power door locks) would still get 12v from the source, which really is the high voltage battery. Basically the 12v battery would be acting like a large parasitic drain. Your high voltage battery would drain faster but you would still have power.
The main battery is only connected to the rest of the electrical system by a contactor using the 12v battery. Without the 12v battery the main battery won't be electrically connected to the rest of the car and can't charge the 12v battery. Chicken and egg. This is for safety.
As you described it, wouldn't the main battery keep supplying charge amperage to the 12v keeping the system alive. Wouldn't the thing I mentioned still apply? Clearly I'm still missing something.
When you turn off the car it disconnects the main battery. The 12v battery quickly dies and the contactors won't reconnect.
Ah, that's the part I missed.
Thanks.
So if I wanted to have a plug in cooler on a road trip I would have to keep the car on for it to keep running. Because the battery wound die from the drain.
Pardon my Tesla ignorance, but does the vehicle "charge" the 12V battery? If so, what is the culprit of requiring frequent replacements?
It's a traditional lead/acid 12V car battery. It does not get recharged.
Replacing mine today. 2 1/2 years.I wish they'd stop doing that. Both my EV Fords had lead batteries and both had to be replaced in less than 3 years.
