Elon wanted no exterior antenna (Anyone sense a theme?)
The antenna was under the dash. Running the antenna up the window in new to me.
When I first got my Roadster some 17 months ago, the radio reception issue drove me crazy. I represent radio broadcasters in my day job and therefore I have more than a passing interest in optimum automobile radio reception. Also, I was moving from owning a BMW in which the radio reception was superb. The radio reception on my Roadster was marginal on FM, and unlistenable on AM.
I tried all sorts of things with the antenna including a temporary mounting of a Wilson fiberglass AM/FM stick antenna, and the installaaion of shielding over the PEM. I concluded after much experimentation that the TESLA antenna running up the side of the windshield with the connected booster yielded just as much AM reception quality as the Wilson fiberglass stick antenna, or anything else I tried (I tried a variety of antennas).
The issue with AM radio reception in the Roadster is the same issue that caused Porsche to ditch the AM radio in its new 918 Spyder. It is the lack of a ground plane for the antenna due to the the car being made of carbon fiber and aluminum. Vehicle owners have been blessed with good AM radio reception since the dawn of radio broadcasting largely because of the great ground plane created by the steel in a normal car. An AM antenna has two parts -- the part the stick up in the air, and the ground. In the TESLA Roadster, and the Porsche 918 Spyder, there is no ground plane and thus very lousy AM radio reception.
Now, add a lack of shielding around the electronic components in the car, and the inherent noise that is generated by a large electric motor, to this lack of a ground plane, and this only further diminishes the AM listening experience. I might add in TESLA's defense, however, that while 20 years ago superb radio reception in most cars was a design and manufacturing imperative, auto manufacturers have moved away from making radio reception a priority as vehicle owners have cared less and less about the quality of radio reception.
Many high-end cars used to and still do have diversity antennas for FM reception which are two FM antennas that electronically switch back and forth to get the best signal and no multipath. Today, it is impossible to find an after-market receiver that accommodates diversity antennas. For AM reception, the stick antenna up in the air with the car as a ground plane gave the best reception although many auto manufacturers found ways to tune their antennas in rear windows to deliver high quality AM reception.
The radio in the Model S seems to work a lot better when I took a drive in it last month. I noticed no noise in the AM section and i suppose the antenna has a ground plane due to the steel in the car. The FM section with HD radio in the Model S is one of the better implementations of the HD radio technology from a consumer use standpoint (i.e. ease of use) that I have seen.
The replacement of the Alpine double-DIN receiver in my later model Roadster with another unit does appear to somewhat improve the radio reception, particularly on FM. I chose the Kenwood DNX-6990HD which I am reasonably happy with (I posted my experience with this swap of radios in another thread). AM reception on the Kenwood for whatever reason is also marginally better, but it is certainly not to the extent that AM is enjoyable to listen to.
In conclusion, due to the carbon fiber and aluminum construction of the Roadster, and the apparent lack of noise filters and chokes at the noise sources in the car, it does not appear that there is much that can be done to improve Roadster AM reception to any appreciable degree.
Thank you for the xlnt writeup John. I guess maybe it's time to start listening to something other than AM.
Art
I'm going to look at the ribbon antenna that's ran up the column and see if the entire ribbon is used as for reception or just the 2mm circle tube the runs up it. If its just the circle tube, I can cut the fat ribbon off, it then appears the column has enough space between it and the window where I can stuff the modified antenna out of sight. I'll be happy then since it will be out of my sight.
