Great A+++ experience with the Wheel Works alignment. $200 total and gave them a $5 coupon, so $195 with tax and all. Not bad for a lifetime alignment guarantee. As I had felt, my right rear camber was off. I'll need to pick up some shims to pull it in camber back there. The right rear wheel was where I lightly tagged a curb which shifted the camber in more negative than I want. I told Omar to take an extra look around that area for anything odd. Always shoot for a -1.0 camber for the front and -2.0 for the rear which I really found I like for the Roadster.
Also nailed the caster settings!!! Thanks to MAUTO for pushing me on the passenger side for the last bit of positive caster. I wasn't that far off from my raw calculation, but surprised the driver's side came in more positive with the caster than the passenger side. I had calculated that the passenger was going to have the higher (+0.2º) reading. But unbolting / bolting, moving shims can and will shift things a bit. Stoked it all worked out.
Caster came out to be (alignment machine):
Left (Driver): 4.2º
Right (Passenger): 4.1º
Cross Caster: 0.1º
Front Toe (was shooting for 0)
Left: 0.00º
Right:0.02º
Camber came out to be:
Front
Left: -0.9º
Right: -1.3º <- need to come in +0.3º
Rear
Left: -2.0º
Right: -2.6º <- need to come in +0.6º
Rear Toe
Left: 0.03º
Right:0.08º
Total Toe: 0.42º (was shooting for 0.18º)
Next step is to order up a bunch of camber shims to pull the right front and right rear in. Going to buy the assortment pack so I have a variety of shims on hand in the future. I'll most likely drop them in myself, although Omar said he can do it too. Best thing is that it won't cost me a buck more I need an alignment performed on the Roadster anytime in the future!
Looking to purchase the V2 shim pack from Sector111:
V2shims
I may also go for the V2 arms as well, that way I can play around more with the front and rear camber some and the lifetime alignment gives me some freedom to play around and experiment.
Also here's the tie rod end / track rod end removal tool I used and highly recommend. I "borrowed" it from the Autozone, they lend tools out for free (you buy it, but they refund your money when you return it). I'm either going to purchase a new one or just keep this one. Its only $35. You may risk damaging the dust boot if you use something like a splitter.
http://www.autozone.com/loan-a-tools/tie-rod-end-puller/oem-tie-rod-end-remover-with-3-in-bolt/409628_0_0/
Manufacturer: OEM
Part#: 27276
