If you really want to charge at 20kW at home, you can buy a DC charger. It's not cheap, but it's possible if you are motivated.Thank you all for replying. It would be great if Tesla could charge upto 80 amps some day.
It's a matter of sizing. Speaking as a maniac with a MY and M3 in the garage, one gets around 46 miles of charge per hour with 240 VAC @ 48A. The point is, "One has to sleep sometime!"Thank you all for replying. It would be great if Tesla could charge upto 80 amps some day.
That's probably not ever going to happen again, since Tesla's history over the last decade has only been REDUCING the home charging power capability.Thank you all for replying. It would be great if Tesla could charge upto 80 amps some day.
I tend to agree with this. 80A was only important because the Supercharger network was either not available yet or was in its infancy. Now that it's nearly ubiquitous in North America, there is no need for high power AC charging for Tesla vehicles.So the nail is in the coffin on that. It's not going back up.
No offense, but I think you're missing the point. It takes about 5 hours to charge an 80 kW-hr battery at 11.52 kW under normal circumstances. Let's see: Here's a list of current Tesla vehicles, each with the long range or P that has the biggest battery size, and how long it takes to charge it at 48A, and how long it would take to charge at 80A:That's probably not ever going to happen again, since Tesla's history over the last decade has only been REDUCING the home charging power capability.
Back in the old 2012 to 2015 time frame, you could choose options of either a 40A or 80A charging configuration, and the wall connectors could do 80A.
With the introduction of the Model X in 2015 and refresh of Model S in 2016 to match, maximum charging was 72A.
Then, a few years later, they moved down to 48A being the highest charging the cars could do. And a year or so later, they replaced the wall connectors with Gen3, which could only supply 48A maximum.
Car | Battery Size | 240 @ 48A Time | 240 @ 80A Time |
Tesla Model 3 LR | 75 kW-hr | 6.5 hours | 3.9 hours |
Tesla Model Y LR | 75 kW-hr | 6.5 hours | 3.9 hours |
Tesla Model S Plaid | 95 kW-hr | 8.24 hours | 4.95 hours |
Tesla Model X Plaid | 95 kW-hr | 8.24 hours | 4.95 hours |
...which will mean that people will have even MORE leftover range in their cars at the end of each day, requiring even LESS charging power to refill it back to the point of range they need. That's the opposite of what you are thinking.I don't know ... As battery technology becomes less expensive they may put more capacity into cars,
I don't think that's me who is doing that.No offense, but I think you're missing the point.
This is that weird fallacy we see frequently from people who don't own or use electric cars. They look at the time it takes to completely fill the entire battery, and then apply that to people needing to do that every night, 365 days a year. That's not how that works. People drive however far they drive. They live whatever distance they are from work. That's the amount they need to refill in a night. It doesn't matter if the battery size is 80 kWh or 180 kWh or 1800 kWh. They only need to replenish however much they used that day--not the entire battery.It takes about 5 hours to charge an 80 kW-hr battery at 11.52 kW under normal circumstances. Let's see: Here's a list of current Tesla vehicles, each with the long range or P that has the biggest battery size, and how long it takes to charge it at 48A, and how long it would take to charge at 80A:
That's definitely not true. The tapering curve is there, sure, but people are only impacted by it with the really high power from Superchargers. People see the power dropping from 200kW to 150, to 100, etc. This home power of 11kW is so extremely low that the tapering curve doesn't need to reduce it until about 98-99% or so, which most people never see during regular home charging because they have a charge limit set lower than that. So home charging is effectively always at full power and doesn't have that "slower above 80%" thing.That time is presuming that one could charge at the rate (11.52 kW or 19.2 kW) all the way from zero to max charge. Which all of you know isn't true; the charge rate with AC charging slows down as one gets above 80% SOC.
I saw people positing that about the Cybertruck, but when they killed the Gen2 wall connectors that were awesome and did higher current and replaced it with the inferior, lower power Gen3 wall connectors, that was their indication that it was not going to happen.Now, come the day when a Cybertruck comes along with a 200 kW-hr battery pack (no idea what it does come with), then maybe this all gets revisited.
Yes, you're remembering correctly. Above 60A requires the disconnects you mentioned. Although, depending on the inspector, if the breaker itself is in the same area and accessible, they might consider that as the disconnect.Im going to defer to those a lot more knowledgeable about this topic than me on this, but I also seem to remember that at least in the US, circuits larger than 60amp need "something" additional as far as hardware is concerned. Maybe it was a disconnect, visible from the installed location of the device requiring that size circuit?
Without the rest of my comment that would be very true. But the vehicles being made now from Ford, Rivian, GMC, Porsche ... They are consuming more energy as well. Which is really what I was getting at. With more energy storage the vehicle can use the energy less efficiently and still have decent range. But you have to be able to put that increased consumption back at the end of the day....which will mean that people will have even MORE leftover range in their cars at the end of each day, requiring even LESS charging power to refill it back to the point of range they need. That's the opposite of what you are thinking.
I can see it coming too, but most of the V2X DC capable equipment is being developed in the 7-10kW range, not 10-20kW. Even these equipment developers want to push the value proposition (ie. keep the equipment price down) and don't see the value in going above 10kW.I could see a future scenario where home DC chargers become more common for situations where people really need or think they need 80-100 amp charging. Put the expensive conversion equipment on the wall instead of in every car when so few people need it.
