Well, this is the model S subforum. I dont have one of those (I have a 3 and Y) but the charging charts that Tesla has for wall connector speeds include model S.
You would be charging currently at 32amps if you are maxing out the mobile connector, so for a model S that looks like its "around" 27 MPH (or more accurately 7.7kW charge rate but its easier for most people to think in MPH even though its less accurate). I also said "around" because the model S in that chart is likely not a 100D.
You probably know how many MPH you charge at now, so if its not 27 its probably close to that.
You can see from the chart that the 50amp circuit (40amp charging) is listed at 34 MPH for a model S, so a difference of about 7MPH from what you have now. If you have the wiring to get the full 60amp circuit for 48amp charging, it would be "around" 41" so even if you are able to max it out, it would be around 14MPH faster.
Unless you are a tradesman who visits home a lot in between sales calls or something, or have a time of use plan where you need to fit all of your charging between midnight and 6amp (so charging speed matters in this case), that difference in speed likely makes very little difference for your day to day usage.
As for "difference in time" thats going to depend entirely on how much of your battery you drive out, but if you know that even at the fastest home charging speed for that wall connector, its about 14MPH faster, you can probably calculate the time difference for yourself.
Wall Connector
Technical Details | Charge Speed
Max Miles of Range per Hour of Charge* | | | | | |
Circuit breaker (amps) | Maximum output (amps) | Power at 240 volts (kilowatt) | Model S (mph) | Model 3† (mph) | Model X (mph) | Model Y† (mph) |
60 | 48 | 11.5 kW | 41 | 44 | 35 | 44 |
50 | 40 | 9.6 kW | 34 | 37 | 29 | 37 |
40 | 32 | 7.7 kW | 27 | 30 | 23 | 30 |
30 | 24 | 5.7 kW | 21 | 22 | 17 | 22 |
20 | 16 | 3.8 kW | 14 | 15 | 12 | 15 |
15 | 12 | 2.8 kW | 10 | 11 | 9 | |
