We're now ready to begin production. We're assuming an initial production run of 50 units.
The camera switch PCB in a case with two remotes and receptacles and connections for the front and rear cameras and touch screen, 12v power, ground, and reverse signal will be $195.00 each. A refundable pre-production deposit of $100 will be required. If we don't reach 50 deposits production will be canceled and deposits refunded. PM me for information on how to make your reservation deposit.
Other parts needed for installation are as follows. These range in cost (depending on the source) from about $100 to $200.
Tesla cables:
CABLES, HSD, LIFTGATE, CAMERA (1006780-00-D) These are shorter cables and 2 are needed, one for a gender change between the long cable (below) and the front camera; the second to connect from the PCB touchscreen receptacle to the existing touchscreen cable.
CABLE, HSD, BODY MAIN, CAMERA (1006781-00-D) This is a long cable. It connects to the short gender change cable attached to the front camera. This long one then plugs into the PCB port for the front camera.
Rear camera (which becomes the front camera in this application) There are several options on eBay, Amazon, or from Tesla. Here are the Tesla options:
CAMERA - REAR VIEW 1006773-00-F (Used on vehicles built before July 9, 2016. OK to use and replace 1006773-00-D and -E.)
CAMERA - REAR VIEW 1061269-00-B Ok to use -A. Used on vehicles built on or after July 9, 2016. Not compatible with 1006773-00-D/E/F.
I'll post another, separate thread for orders in the TMC Tesla Parts for Sale. Again, PM me for how to make your reservation deposit.
Um, what? I figure there's a typo there somewhere...Finally got the cables I ordered from my local SC. They were packaged very... oddly.
In any case, total came to about $77 after tax for all 3. There is also a new PN for the BODY MAIN camera; 1006781-00-E instead of 1006781-00-E:
View attachment 296397 View attachment 296398 View attachment 296399
And that looks like a cable part number? (Cable for the camera, I guess was meant...)
Thanks. If we end up not sourcing the cables from a Chinese importer as people did on the last go around of the camera production we will all be ordering them from the dealership just as you did. Very helpful.
At the pace of deposits (we now have 18) I'm concerned that we'll never reach the minimum of 50 orders required to begin production.
Do it ! Its not been posted on TM's forum either. Something is preventing me from post a new thread there, so I can't.Has this been posted to r/teslamotors on reddit yet? Could access additional audience. I don't post much here, would that be ok to do?
appleguru, do you think it your method will not work on AP1 or earlier cars? Or is it that you don't have one to test and are just making the safer leap that it might not?
If you can get this working, it will be a blessing for many people. I can say, SIGN ME UP for one of the switches that incorporates the CAN.
You don't mean the OBD II port right? You are referring to the hidden connector they plug into. Isn't it RJ45 on earlier cars?
