I'm wondering if anyone else is having the same experience, just want to confirm if it's normal. When I have the front and rear set to Auto and set the temp to 68deg for example, the rear air comes out much warmer. I can remedy this by setting the rear temp manually to 60, and only then will the rear air temp match what's coming out of the front.
A separate issue is that on auto, the fan speed selected is almost always too low so I end up having to manually choose the fan speed and temp.
Basically if you set the climate to full auto, the front passengers have a very different experience (in temperature) than the back seats.
