Just upgraded this morning from 2018.50.6 to 2019.8.4. Got sentry mode, dog mode. Didn't get advanced summon - still catching up on recent forum posts so not sure if I should have expected this on my X100D '17 AP2.5/MCU1 build. Not that I expected to use "snail mode" other than showing it off...
Ours has had this issue for quite some time. I have gotten use to waving the wand near the bottom, middle of the rear window, if all else fails, I use the remote to lock, unlock the doors. I have seen the wand stay locked because the charging system was being used as a shore power and it wasn't apparent by the color ring on the plug receptacleI have same issue at home hpwc gen 1 and today at a supercharger port won’t open with wand ..mine is 2018 p100 with mcu 1
I am noticing two issues:
1. HPWC isn't opening my charge port. Have to go in the car and click open from the screen.
2. When someone or something is in the back seat, with no seatbelt on (usually a backpack) then the screen flickers over on the left of the driver screen and the exclamation light flashes on the large screen.
1. You can just press on the charge port door if key is nearby.
2. It is supposed to do that. Seatbelt use is mandatory. Do not place anything on the seat.
Neither of the above works -
With the key - I actually had it in my hand. With the update it does not work like before.
The seat - The point is that it used to show the symbol Now it flickers and flashes between the normal screen and the seatbelt one.
It is possible you have a problem with the fob. Did you try a long press on the trunk release portion of the fob? That is also supposed to pop the charge port (mainly needed when not using a Tesla charger). It is not at all surprising a feature changes with a software update. Changes in how features operate is the whole point of software updates. Although I have not noticed this particular problem with my car. You will need to contact Tesla if it continues. Not being able to open the charge port significantly affects your ability to operate the vehicle.
I still think the seat belt alarm is operating normally. It even tells you in the owners manual to not place heavy objects on the seat (I took "heavy" to mean anything heavier than a sweater).
Got 2019.8.3 two days ago. I have the same 2 issues with this update.I am noticing two issues:
