Model S 2022+ Project: connect fridge (10Amp), 2 additional USB chargers and some extra LED lights which all work whilst car is asleep.
Source is Li-ion battery 16V, 6.9Ah!!
Left and Right footwell hold VCLeft and VCRight (see electrical diagrams in file MS_Sop16-Sop20230118.pdf), See service manual 17: electrical, 1715: Electronic Control Modules, Module – Body Controller – LH and/or RH and 1710 Harnesses, Harness-Body-RH, which shows detailed picture of connector X-036/X-056
All connectors are on top of the module, also the feed from the battery is 16mm² = J14 X036 (left) and 56(right). This module has connectors x-030, 31, 32, 33, 34, 35, 36, 37, 38 and 39.
Assuming that:
- The thickness of the wire corresponds to the amperage it can handle and,
- That the current drawn through the cable will be monitored and if deemed incorrect, will trip the corresponding E-fuse.
This seems the path to follow:
- step 1: is to locate a cable that will allow for the current to be drawn from it.
- Step 2: the monitoring system should “see” a normal behaviour so as not to trip the fuse.
- Step 3: power always on or not?
e.g. 1: connector X-034 – 3 leads to the front seat controller with a 3mm² wire. This can handle a lot of power (step 1), But it will also be seen as ‘normal’ if a constant current is used on that wire. Assuming that the wire is used to supply power to the seat heater, then using power from this wire on a constant base will be seen as “normal”, as long as it is not in combination with the use of the seat heating (step 2). And final question: is there power on the wire when the car is asleep? This can be tested by powering the car off in the main screen under after which power can be measured with a (Volt) meter (step 3).
e.g. 2: The ODB-II connector provides an always on wire on pin 12. (step 3), the wire is 0.35mm² and will therefor only handle around 5 to 6A @16V (step 1). It will probably be fused around 2 to 3Amps (I guess). Using this source as constant will be seen as “normal” (Step 2).
After studying the Wiring diagrams and looking for cables that are at least 2mm², the following options appear:
Front footwells:
The X-036 connector (LH) or 056 (RH) is the supply of the Module as is by far the thickest cable (16mm²) This cable should not be able to monitor any additional current because anything might be switched on in the car during use. It might however be able to monitor abnormal current when the car is asleep. (Drawing 10A per hour means that the 16V battery will need to be charged almost every half hour). Then again, in Camp mode and with 10A drawn from the 12V socket would create the same situation.
Connecting to this cable seems the most favourable option but is also quite visible. But it might just be so that this connector allows insert connections in the slots that are visible! (Any body knows?)
Body Controller LH:
- X-031(2mm² cable that runs to the 12V Power Socket, pin 1), but this is not always on. It might be made to be so by feeding it directly from the X-036/X-056.
- X-030A (2mm² cable that runs to liftgate, pin 28 & 29 BU & YE. Runs along doors on floor, might be always on: it was in the older model S.)
- X-034 (3mm² cable that runs the front seat controller, pin 3, easy access and out of sight, but probably not always on: to be measured)
Back of car:
- X-030A (2mm² cable that runs to liftgate, pin 28 & 29 BU & YE. Connects to X-391 above safety belt, might be always on: it was in the older model S.)
Body Controller RH
- X-447: (3mm² that runs to External Amplifier and will provide power but when car is ON.)
- X-054: (3mm² that runs to front seat controller, possibly only when car is ON.)
- X-059: (5mm², but for HVAC… better left alone)
Best bet:
- For fridge: connect 12V socket with bridge to 12V “always on” via X-036/X-056 or run extra wire (1,5 mm²) from X-036/X-056 to fridge. OR make harness and continue to back of car to run USB chargers and LED’s.
- For additional USB and Led: connect to cable that runs from body controller to liftgate: might be detected as a “leak” if continuous current is drawn and thus trip the E-fuse.
If anybody has feedback or ideas: MUCH appreciated!!!
