So I had a Nakamichi CD400 Head Unit sitting around that I used in my previous car and decided to throw it in the Roadster. It was setup by chance with the same "VW Jetta" connectors that are used in the Roadster. I checked one speaker, the power, switched power and ground, concluding the harness was good enough to hookup and test. Plugged it in and discovered the speakers worked / routed perfectly. So it was an easy plug and play! The whole sound system went through a total change. The Nakamichi pushes more power out to the blaupunkt speakers so they respond so much cleaner, better and have less distortion. So I get higher highs and lower lows. The head unit is very good looking and clean too. Its a simple head unit and I have quick access to adjusting highs, mids, and lows. Simple and Great UI, exactly what you want and expect from a head unit. Tuner appears better. Has a Sub out and Line-In so I can hook an ipod, iphone, or connect to a generic line in plug / headphone jack. Will do the aux hookup next weekend.
http://www.woofersetc.com/p-760-cd400-nakamichi-sound-quality-amfmcd-player.aspx
Here's a pic of what the lighting looks like and the different modes
Pics of it installed (daytime):
