Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Shake Down Cruise Today
  1. #11
    Model S Sig Perf, VIN 586
    Apr 2012
    Rocklin, CA
    310wh is about right for the speed and usage. The trip meter adds up. Seems likely that started with 240 projected but not rated? The vampire usage could explain it too, but I think the vampire usage shows up pretty quick after starting out, doesn't it?
  2. #12
    Nov 2011
    Atlanta Georgia
    I think I started full. I have had the car 1.5 days. That being said, I thought the 76.5 KWh was a range charge? Yes it was 310 Wh/mi.
    Model S Signature Vin 1034
  3. #13
    Roadster #1144 + Sig 114 dsm363's Avatar
    May 2009
    Texas
    I believe ideal range is based off of 265 Wh/mile if that helps with calculations.
    Roadster #1144
    Model S Signature Performance #114
    Moderator - Model S, Mountain/Southwest, Off Topic forums
  4. #14
    Model S P6415 zdre's Avatar
    Jan 2010
    St. Louis
    Quote Originally Posted by brianman View Post
    I presume you mean: 310 Wh/mi. Doesn't affect the numbers, but it's always good to get your units right.
    310 Wh/mi. * 211.8 mi. = 65658 Wh = 65.6 kWh
    85 kWh * 90% = 76.5 kWh for standard charge
    65.6 is indeed quite a bit less than 76.5 for a mere "8 mi." projected remaining
    Perhaps he started with only a partial standard charge.
    Please correct me if I'm wrong, but I thought that only 80% is actually available in standard charge mode since the battery is charged to 90% and discharged down to 10%. When the projected range is 0, there are still ~8.5kWh of reserve charge left.
  5. #15
    May 2009
    Texas
    Quote Originally Posted by zdre View Post
    Someone correct me if I have these numbers wrong but that is on the Roadster (I'm pretty sure those are the correct numbers for the SOC range). On the Model S you go from 90% to 0% SOC (there still is something left though even when you run out as you have a month to plug back in before trashing the battery pack).
    Roadster #1144
  6. #16
    Yah, I thought it was [10,90] for the Roadster and [0,90] for the Model S.
    Truly Electric Spaceship-Like Adventure ~ Signature Model Spaceship
    PLEASE NOTE: these musings are the copyrighted intellectual property of the author, and are intended as part of a conversation among the Tesla Motors Clubs membership. My words may not be quoted by any third party outside the Tesla Motors Clubs forums, without my expressed consent. Especially the NYT, which is clearly ethically challenged.
  7. #17
    I think there is maybe a 10Kw safety at the bottom that you could use for the '2 months' unplugged at 5% charge before the battery is really hurt
    Safety factors are kind of important in engineering. Over do it if you can for safety if the cost is reasonable.
    I used most of a range charge and had quite a few kWhrs left based on the used power - I think it is a good thing
    -(5/10/13 4.4v1.31.11) 'Joules' 12/1/12 - 8793mi @ 378.8Whr/mi Zextraterrestials S (tory) - Page 8
  8. #18
    Someone on TM forum (Teotawaki, IIRC) managed 4-5 mi limping home after 0 range left. So there's a bit down there!
  1. Adaptive Cruise Control
    By Kevin Harney in forum Technical
    Last Post: 05-11-2013, 04:08 AM
  2. July 28, 2012 cruise!
    By franklandfield in forum California
    Last Post: 06-05-2012, 10:07 AM
  3. Adaptive Cruise Control - Wish
    By ibcs in forum Model S
    Last Post: 12-23-2011, 08:47 AM
  4. Adaptive Cruise Control
    By William3 in forum Cars and Transportation
    Last Post: 04-23-2010, 08:49 AM
  5. cruise control
    By Kipernicus in forum Technical
    Last Post: 12-26-2009, 12:21 AM
