Tein EnduraPro settings suggestion?
What happens if you do the wrong thing and rotate adjustment all the way to 32? My installer did just that and then backed off to 24.
Which direction did he turn it?
On Tein's website it says the adjustments should be done like this:
"You can adjust damping force with the adjustment dial, or click, on the shock absorber. Turning it clockwise, the end is level 0 (zero): the stiffest. Turning it counterclockwise from there, the damping force becomes softer. You can notice a click at each level. The 16th click is level 16, the softest damping force. If you lose count, just go back to level 0 and start again."
