I'm planning on asking these questions before I accept the system design:
1. Are both (I have 2-Powerwalls+ in the design) model 158000 - 7.6kW?
2. What is the DC to AC ratio?
3. I'd like to see the Plan set.
4. Can I get panel edges on all 4 sides?
5. Will I get two inverters? I don't want to see clipping. (I'm looking at an 11.6kW system)
6. Will they wire the panels so I can charge my car from solar?
7. Will they put the car charger on the backup side. (I know it will be. I just want to make sure they know I have a car so they add a CT to monitor it)
8. Will I be able to send extra PV power to the EV while on Grid?
9. Will they install a CT on the Wall Connector?
10. Will I be able to charge the car with excess solar while grid power is out? (I've seen the link that explains this. Things change all the time. I'd like to ask)
11. Will they install one 20amp 110v outlet on the grid side so I can know when the grid is down? (And charge my car if the PV fails for some reason)
12. Will they run the wires through the garage and into the attic so there will be no EMT conduit on the outside of the house?
13. Will they install the powerwalls inside the garage?
Is there anything else I should be requesting / upgrading with Tesla?
